Old 07-22-2009, 11:51 AM   #16
sokar's Avatar
I've heard of people running ARO into their engine through the fuel tank. Is this a good idea?
sokar is offline   Reply With Quote
Old 07-22-2009, 11:53 AM   #17
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
No WD-40! I agree with frank, the GMK is the way to go. There is also a brand called blue block that works well too. ARO shouldn't hurt your carb in any way. The best way is to use the GMK system. I rarely use any ARO at all. Only when the engine is going to sit for more than a few weeks. With the fuel I use(odonnell) you really don't need any ARO.
http://carolinasrc.com/Webstore/Scri...idproduct=4229
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-22-2009, 11:54 AM   #18
I would not do that BECAUSE the 3 needles that the fuel goes through is ver small and sensitive. I just fell that doing so will allow the oil to stiffing in side the HSN causin it to lean out and become unpredictible in tuning
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-22-2009, 12:15 PM   #19
JayL's Avatar
1. wd-40 will swell the o-rings like nothing
2. don't use marvel mystery oil if your crankshaft is filled
JayL is offline   Reply With Quote
Old 07-22-2009, 01:11 PM   #20
I ran my S3 on WD40, but if its good fuel..... I doubt it
ARO arent expencive, why risk youre expencive engine?
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 07-22-2009, 01:35 PM   #21
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
the only time i use WD40 is when i tear down my engine and clean it up, then after i sit the engine disassembled in fuel over night to get all the WD off and out...it's a penitrating oil and works great for cleaning.
I don't use any type of after run oil unless the motor is gonna be shelf-bound for awhile...and when that time comes I use ATF and never had a problem one on any type of crank standard, coated, or filled...but that's just me
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 07-22-2009, 01:51 PM   #22
jaybird's Avatar
wd40 ...no way...us after run or the mystery oil.....wd40 will mees it up !
3 in 1 oil will work also on the carb..
jaybird is offline   Reply With Quote
Old 07-22-2009, 01:54 PM   #23
sokar's Avatar
Ironic that I start this thread right after the WD40 guy dies. Hahaha
Anyway I just bought more ARO and will be using that in both the carb and glow plug hole. Out of curiosity, what makes WD40 inferior to ARO?
Old 07-22-2009, 02:40 PM   #24
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 thats the stuff I am talking about. I didnt like putting it through the fuel inlet. I take the plug out and dump in in the hole, after I make sure its clean. Then stuff a paper towel in the glow plug hole and spin the engine on the box. I do have one question. The instrucktions say to put 5cc in the engine. That is A LOT. If I fill up the tube to 5ml and then put that much oil in the engine it is harder than hell to start next time and it smokes for a min until the oil burns off. Is 5cc necessary? I could see if the engine was going to sit for months but 5cc seems excessive.
GMK ARO
Old 07-22-2009, 02:47 PM   #25
Your best bet would be to use after run oil. You aren't fixing a squeeky door.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-22-2009, 03:12 PM   #26
Send a message via AIM to nitrorustler135
exactly...its not a sweeqy door...i alayws use a drop or 2 of ARO on top of the slide and move it back and forth to lube it so that there isant any binding
if its fast its a rustler
nitrorustler135 is offline   Reply With Quote
Old 07-22-2009, 03:42 PM   #27
Trader Rating: 15 (100%+)
i was thinking the instructions said 2cc was plenty but i could have misread it. I usually pull about 5cc in and push it out to the 3cc mark then shoot the rest back in the bottle. GMK is the only way to go. The only downfall it likes to hang onto the plug and is a little hard to start.
Jonathan Bell is offline   Reply With Quote
Old 07-22-2009, 04:20 PM   #28
after run!!!
jato guy is offline   Reply With Quote
Old 07-22-2009, 05:03 PM   #29
slow coach's Avatar
for very short term wd40 would be ok but it does evaporate so for storage of any length after run oil all the way
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 07-22-2009, 05:34 PM   #30
wouldn't it be great if AROs are available in aerosol cans
cheapskate.brok is offline   Reply With Quote
