Old 07-21-2009, 08:51 PM   #1
dadsvtechonda's Avatar
Default 8ight t 2.0 flaws and fixes
just wondering about the losi 8ight t 2.0 flaws and how to fix them
Proud Supporter Of WWW.READYROLLERS.COM
(thanks for all the support rome couldn't do It without you)
Losi 8ight T 2.0 Alpha S852 (Orange Head)
www.hobbyhut.com
dadsvtechonda is offline   Reply With Quote
Old 07-21-2009, 09:19 PM   #2
pyromania's Avatar
Trader Rating: 18 (100%+)
Not much. Get some longer screws for the wing mount and camber links, check your shock ends, and just go through and check all the diffs and shocks.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 07-21-2009, 09:20 PM   #3
air8's Avatar
Here ya go. This should answer you plus much more.
8IGHT 2.0!
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 07-22-2009, 01:05 AM   #4
losi_racer's Avatar
Trader Rating: 25 (100%+)
get longer camber link screws, you can get longer wing mount screws or just loctite them since you dont usually mess with them. replace all the shock ends. and keep a supply of bearings around
air8: you linked the wrong car
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 07-22-2009, 03:01 AM   #5
vladconnery's Avatar
Trader Rating: 35 (100%+)
What I have discovered so far.
1. Rear hubs bearings will wear out fast (outer). Problem they were to small. Fix kings head rear hubs (alum). They come with the larger diameter (outer) bearings. don't buy the losi alum hubs you will still experience the same problem.
2. Shock tower screws F/R. Problem they have a tendency to back out. Fix use longer screws with lock nuts.
3. Handling. Problem it turns on a dime. Fix hang on and enjoy.
4. Speed. Problem its fast and smooth. Fix hang on and enjoy.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 07-22-2009, 05:12 AM   #6
Domo3's Avatar
8IGHT 2.0!
buggy thread
Domo3 is offline   Reply With Quote
Old 07-22-2009, 06:01 AM   #7
Dont just check
REPLACE the outer wheel bearings
and REPLACE the shock ends
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
