Old 07-21-2009, 01:24 PM   #1
Default OS Vspec leaking oil.
Hey guys. My OS motor seems to be leaking oil out of the motor itself. I originally thought it was my exhaust gasket but after further inspection it looks like it is leaking from the motor itself.
I asked someone at the track and they told me to pull off the motor, pull off the back-plate and apply a small bit of high-temp adhesive to the tip of the plate before sliding it in.
does this sound accurate? I am looking for some extra opinions.
terzianator is offline   Reply With Quote
Old 07-21-2009, 01:28 PM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
I didn't know your OS used oil.
But yes you can try that, is it leaking from the front bearing? Or you could have the 2007 or older engine blocks and they can have some small cracks.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 07-21-2009, 01:28 PM   #3
take it apart - clean good - then seal high temp Luck7 - Amain hobbies
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-21-2009, 01:35 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I seal the backplate of every engine before I even break them in. Ihave been told not to do this on os engines but that didn't stop me. I usually seal the carb where it meets the block but I did not with my newest os speed because it uses an oring and I will just replace it. Permatex gold From any automotive store works well and so does the lucky7 sealant. Do yourself a favor and seal it.
Old 07-21-2009, 01:48 PM   #5
houston's Avatar
Trader Rating: 91 (100%+)
more than likely a cracked case
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
