Old 07-21-2009, 07:48 AM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default What's the best way to actually put after run oil into the engine?
Do you put the drops into the gas tank, do you remove the glow plug and put it in the opening at the top, do you remove the air filter and put it in through that hole or something else entirely?
Thanks a lot.
I am not a "Tech Master" nor even close. I simply have a lot of posts. If you want some sage advice, the only that I can give is don't listen to me.
Garet Jax is offline   Reply With Quote
Old 07-21-2009, 08:52 AM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
in the air filter and glow plug hole. if i tear an engine down i drench that thing
Mark Buecker
8&stuff is offline   Reply With Quote
Old 07-21-2009, 09:18 AM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
through the fuel inlet with the GMK Supply system
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-21-2009, 09:45 AM   #4
JayL's Avatar
I like the bottle like nova with a thin long spout, then just like 8&stuff said.
Some engines tell you not to inject it into the fuel nipple so I don't
JayL is offline   Reply With Quote
Old 07-21-2009, 09:52 AM   #5
omarwashington's Avatar
sorry for off topic question
but is it ok to use motor oil like 10w30 mobil1 synthetic as after run oil?
I think this has been talked about before but I'd just like to make sure
RCCARS!
omarwashington is offline   Reply With Quote
Old 07-21-2009, 09:55 AM   #6
fatdaddy's Avatar
i dont think regular motor oil would burn off very well. i make my ARO with a 50/50 mix of Marvel mystery oil, and automotive ATF fluid.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 07-21-2009, 10:18 AM   #7
elkman's Avatar
Default Maybe not
Monty Houston, Whom I trust very much , told me NOT to use Marvel's oil.He said it swells up seals and other soft materials . He told me to use 100% synthetic motor oil like Mobil 1. I may get this part wrong but I belive he told me to mix 30 weight with a 80 weight to come up with around a 50 weight or so. Monty, Chime in here if I screwed it up.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 07-21-2009, 10:19 AM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-21-2009, 10:23 AM   #9
megasaxon's Avatar
Trader Rating: 25 (88%+)
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
use horizon hobby afterrun oil and put it in the glow plug hole, about 6 drops or so, turn the motr over a bit to get it worked around and you're good to go...
Team Associated RC10GT
Team Associated RC10GT2
megasaxon is offline   Reply With Quote
Old 07-21-2009, 10:36 AM   #10
Trader Rating: 32 (100%+)
I read somewhere afterun oil will eat away at your rubber seals, and not to put it in the carb. just the glow plug
Z01B | Xerun 150A 2000kv | Hitec | Desire-power 6S LiPo
Z01T | Tekin RX8 1700kv | Hitec | Desire-power 6S LiPo
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 07-21-2009, 10:38 AM   #11
Truthfully I rarely use ARO. Only if I am storing the engine for an extended period of time. I do use odonnell fuel though, which leaves lots of oil in the engine as it is.
-Koby Kubrin-
Old 07-21-2009, 10:49 AM   #12
underway's Avatar
Trader Rating: 48 (100%+)
+1 on the GMK Afterlife system...
underway is offline   Reply With Quote
Old 07-21-2009, 10:59 AM   #13
Garet Jax's Avatar
What's the GMK supply system?
Old 07-21-2009, 11:03 AM   #14
Garet Jax's Avatar
Here's why I couldn't find it:
Its called GMK afterlife.
Old 07-21-2009, 11:05 AM   #15
Garet Jax's Avatar
Wish I'd seen this
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
Tuning Guide for Nitro? K_King Electric Off-Road 6 02-16-2007 03:51 PM
TNT Discussion - MONSTER TRUCKING!!! BloodClod Singapore R/C Racers 4263 04-13-2006 09:48 PM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 07:49 AM
Formula 1 GP Windtalkers Malaysian R/C Racers 150 10-18-2004 08:59 AM
