Old 08-16-2009, 12:06 PM   #46
PTP Racing's Avatar
Ive been using the Reedy 2100mah lipo to run my 2 Hitec 5955 servos in 1/8th buggy. I usually dont worry about charging it during a race day. After running 2 tanks practice (near 10 minutes each) 3 qualifiers and a 30 minute main it usually takes 600mah or so to recharge. I estimate being able to run 2 hours without charging safely but havent tried it yet because its better to be safe then sorry.
I was charging it recently when I saw smoke and the charger shut off. I am not sure what caused it but the positive wire was melted a little. I taped it up continued charging and was able to run 30 minutes on it without issue. I wanted to go back and put some heat shrink tubing on it but the wire was melted into the connector. In trying to get it out I ended up ripping the wire right off the pack. So Im sitting there 1am the night before racing and rip the damn wire off the pack because I forgot all about it till the night before this weeks race. I opened it up and it was kinda scary. There is a lot of different tapes used and the cells look like their connected to each other with some sort of foil. I gave up and used my back up NIMH pack for the race yesterday. I though the difference in voltage was going to make the servo action noticably slower (I run unregulated lipo) but it wasnt too noticable.
Today with a clear mind I got in there and soldered a new lead onto the pack and taped it back up with as much of the original stuff and some electrical tape and put it on the charger to balance charge. I noticed one of the cells voltage was about .3 volts lower than the other. It balanced out and charged up. I hope its OK but am not sure I can ever really trust it again.
I would like to get a smaller lipo receiver pack. Ive been looking at the Reedy 1600 since I know the balance connector would work since I already have one of their packs but I wouldnt mind getting a smaller lighter 1200 size pack. I figure 1200 ought to easily be able to handle even the longest hour long mains and probably enough juice for a full day club racing but I dont know where I can find a pack like that. There are so many odd size lipo packs. I need one that fits inside the battery box on the RC8B which is made the size of a hump pack with not much if any extra room.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 08-16-2009, 12:47 PM   #47
Integra's Avatar
ebay 900's would do the trick......a full hour might be a little much for them tho.....i know on my buggy with 9351 on throttle and 5955 on steering it took 650mah after a 45 min main with 7-10 min warm up......and at a little under 6$ a piece....can you really go wrong ?
Old 08-16-2009, 01:27 PM   #48
PTP Racing's Avatar
I do hour long mains somewhat regularly so it wouldnt really be worth it unless I can do them.
What kind of balance plug do the ebay lipos have on them?
For that matter what balance plug do the Reedy packs I am using have on them? All I know is they are the right ones for my charger and everything works without adapters.
I'll probably just get the 1600mah Reedy pack. I did notice one odd thing though. The 1600 pack costs more than the 2100 pack. Is it me or does that make no sense?
Jason Miller
Old 08-16-2009, 02:25 PM   #49
Integra's Avatar
imo no sense at all.
go for the 1600's i would hate to steer you wrong with the 900's...but they are worth having on hand for quali's and shorter main's....at a little over 50g they are 1/2 the weight of a 2000.
Old 08-16-2009, 02:40 PM   #50
PTP Racing's Avatar
I checked ebay and the only 900mah lipo pack I could find looked like it wouldnt fit.
I searched 1200 2 cell lipo and 1500 but neither had any matches.
Hopefully this pack I have will continue to work for me. Balancing ought to cure any issue it may have had....I hope
Jason Miller
Old 08-16-2009, 02:48 PM   #51
Zerodefect's Avatar
1000 mah should do it......but your running a RC8B right?
What are the battery box dimensions on that thing? Your running the front box right?
This might fit the front box:
http://www.hobbycity.com/hobbycity/s...Receiver_Pack_
This is what I'm running in my Xray 809 ( should be good for a 1hr main):
http://www.hobbycity.com/hobbycity/s...idProduct=9490
I forget the box dimensions for the RC8.
Zerodefect is offline   Reply With Quote
Old 08-16-2009, 02:56 PM   #52
Integra's Avatar
the red or green 900's fit where hump packs do....so technically they should fit.....i know for a fact a buddy of mine is running them in his RC8....not sure of the bat config...but i know he's ran them in the past.
Old 08-16-2009, 03:29 PM   #53
mudboger07's Avatar
Ok, does anyone know what type of balance plug is on the losi 2000mah rx lipo? It's differsnt than the plugs on all my comon sence lipos? Can i get an adaptor for it to balance it?
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 08-16-2009, 03:57 PM   #54
Zerodefect's Avatar
Its probally an Alighn type tap. Is it short or long? Jst-xh??
Short like the plug on this:
http://www.maxamps.com/HYP-MULTI-ALIGN.htm
Old 08-16-2009, 04:45 PM   #55
mudboger07's Avatar
heres the battery, the plug is about half the size of a comon sence 2 cell bal adaptor.
Ken
Old 08-16-2009, 05:04 PM   #56
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
i have that same battery and the jx one that is in the swallow eq charger does it fine the same connector that u use on a nosram 2 cell or lrp should do it for ya
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 08-16-2009, 05:19 PM   #57
Zerodefect's Avatar
bah
Old 08-16-2009, 05:54 PM   #58
air8's Avatar
I bought a couple of these batteries a few weeks ago. All working fantastic so far. I havent' got to run a long main yet though so I can't comment on how long they last. But in my Losi 2.0 I can completely surround them with foam for protection. The 1500mah and 2000mah batteries I had been using fit so tight that I couldn't use much foam and the batteries would only last 10-15 races, which is about half of my season. That sucked to spend $50 for a few months worth of racing. So I'll see how these do. I don't forsee any problems though being more protected than the larger ones.
These are 900mah, 7.4v, $7.50(usd), I'll measure the dimensions when I get home tonight. They fit great though with the non-hump lid.
http://www.hobbypartz.com/kahaoubrmo8.html
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 08-16-2009, 06:20 PM   #59
Integra's Avatar
you can get the 900's on ebay for 5.60$ a piece with free shipping....there should be an auction with 3 for 16.80$ i have 8 of these i have in circulation...they fit the losi box perfect with the flat lid.
http://cgi.ebay.com/3x-7-4V-900mAh-L...d=p3286.c0.m14
Old 08-16-2009, 06:26 PM   #60
Cory Kerber's Avatar
I have still not purchased any of those. I think the time has come for me to push the big blue button. I'm running 5955 and 7955, so i'll give it a shot regulatorless.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
