replacement grp piston?
i pulled the piston out and at the top it has a chip. i though about trying it the way it is or does anybody know of a replacement piston only i could get that would work? the sleeves perfect and i have a good conrod. help is appreciated. thanks
Originally Posted by 8&stuff
(Post 6090504)
Look on there website? |
(Post 6090504)
Originally Posted by token
(Post 6090519)
You will need to replace the whole thing: piston sleeve and rod. The last time i checked Amain has a few parts left
And yes +1 on what Token said, you will need to replace all 3 things. |
yeah...thats what i knew. although the sleeve is perfect and i have a new rod. just need a piston...
Originally Posted by pinky2252s
(Post 6090530)
ohh ok now i under stand what he was asking
(Post 6090947)
your not going to find just the piston from any dealer... maybe ebay |
is it possible to find a replacement from a different engine with same stroke/bore? the skirts shiny and new. the rod is perfect too. if i have to il toss this thing but i figure theres got to be a piston i can throw in there for a couple gallons..
i would not suggest it.
(Post 6091301)
pistons and sleeves are matched at the factory. they need to be replaced together and broken in together.
just buy the piston and sleeve and sell or use the sleeve as a replacement
Keep the rod. USe it during the break in of the new piston/sleeve and then replace. Once the engine gets tired. Replace the bearings and send the piston and sleeve out to a place like OS Rocket and use that rod again for the breakin again.
Originally Posted by willbe
(Post 6093014)
look on ebay
I know a guy selling some GRP stuff - go to www.denver-rc.com and look under the buy/sell/trade |
thanks token.
