What does a motorsaver air filter do that the stock one won't?
I have an OFNA Hyper 8 and the stock two stage air filter. I've heard good things about the motorsaver air filters, but what exactly would that do that my stock filter wouldn't?
Cost you 40.00. It may be a better filter element but if you properly clean and oil the stock one with the prefilter, you shouldn't have any problems. I run the stock filter/prefilter on my Kyosho's and never had any issues.
The motorsaver top will fall off,let filters fall out and your motor will suck all kinds of dirt and debris. Stocker won't do that.If you really want a filter check out the proline low profiles. Just my 2c.
Originally Posted by pooldoc
(Post 6086952)
by the sound of it they will do more harm then good :D
Originally Posted by gkn0315
(Post 6087107)
that is not true
(Post 6087374)
that is not true
Do NOT use the proline low profile airfilter. Gauranteed to kill your engine.
I have been racing on-road and off-road nitro for over 10 years and IMO
MotorSavers air filters are the best. They allow your engine to breath better because they have more suface area and they are very light weight. I bring three filters to the track and usually use two, but if the track is very dusty I'll use the third filter with the included foam pre-filter for the main. Like most things in racing It's not fools-proof; you should take the time to put alittle oil on the base and make sure the top is on properly. Alot of racers like to use the stock filter and will use it for the whole day, maybe change the pre-filter. I think by changing the entire filter you get better engine perfomance and mileage. Hope this helps. |
Originally Posted by slaytanic
(Post 6088593)
(Post 6088593)
They are great filters - sorry they did not work well for you Sorry but motor savers suck....... stick with the dual foam filters and you should not have any problems - so - I dont even carry these anymore |
Motorsaver filters are not good. The top can fall off but it can also suck dirt around the base. Trust me I found out the hard way.
Ive used the Proline filters without issue. |
Originally Posted by sokar
(Post 6086913)
Originally Posted by RBMike
(Post 6090795)
Let dirt into your motor.
