Old 07-18-2009, 06:47 PM   #1
Default rc8 steering mod help
one thing i dont get about the mod is the part where they say to cut the 3 holes off the steering crank (bell) plate and turn it over and install.i know how to cut it but the turn it over part gets me and this is why,the plate is angled and kind of points a certian way,if i turn it over it will point the other way is that right,or should i turn it over mark it than cut and install,should the postion stay the same or change,should it point the same diriction or the opposite way. thanks for the help
bigguyrc8 is offline   Reply With Quote
Old 07-18-2009, 07:30 PM   #2
tallyram's Avatar
cut both sides and then flip it over keeping it pointing in the same direction. flip it from left to right or right to left, not front to back. that will keep it in the correct position.
tallyram is offline   Reply With Quote
Old 07-18-2009, 07:36 PM   #3
ok so im going to slip it right to left mark it than cut it is that good?
Old 07-18-2009, 07:46 PM   #4
tallyram's Avatar
just cut the three holes off of each side. now flip it over from right to left. done!
Old 07-18-2009, 07:53 PM   #5
thank you, did you use your stock turnbuckels,if not where did you get the ones your useing now ,part # if possible
Old 07-19-2009, 05:46 AM   #6
tallyram's Avatar
i bought losi turnbuckles, but never installed them. i left the blue associated turnbuckles in and have not had a problem in the 5-6 months i've been running with the mod! if you run on a track with large jumps or crash a lot, then don't use the factory blue turnbuckles. part# losa6542, they are 60mm so you need to dremel off 5mm per side to be correct length, 50mm.
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Team Associated 1/8 Electric Buggy Info and Tips Kevin Boyle Electric Off-Road 812 09-02-2013 07:22 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
2009 Silver State Nitro Challenge motoxpj Nitro Off-Road 256 12-10-2009 01:27 PM
Associated FT RC8 /w Jammin 16mm Big Bores cbaranski R/C Items: For Sale/Trade 8 12-31-2008 09:24 AM
Associated RC8 Worlds Edition ChrisL Nitro Off-Road 33 10-01-2008 01:38 AM
8ight vs. RC8 revracer222 Nitro Off-Road 22 07-17-2008 08:06 PM
