Old 07-17-2009, 09:17 PM   #16
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by jpz_67 View Post
Very interesting guys. From my personal experiences I get lower temps and of course more power with a higher nitro content, therefore I could lean the mixture more. I tried some 20% on my motor just so I would know and all that happened was a slight loss in power and the temps went up. That is the only reason I am not so sure on the situation. Maybe I should have removed a shim or ran a different plug?
Temps will go up a bit because less fuel is going through the engine. Don't worry about it unless it goes WAY up. Tune for performance, not by temp.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-17-2009, 09:23 PM   #17
jpz_67's Avatar
Trader Rating: 56 (100%+)
Numbers dont bother me. My friends use my exergen more than me.
I tune by smoke,sound and reading plugs. I just dont see where the increase in mileage comes from. Thanks to all who answered my questions though. I will let this one rest.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 07-17-2009, 09:25 PM   #18
wingracer's Avatar
Sometimes the reduction of bottom end torque means you end up pulling the trigger harder and any mileage gains you might have noticed are out the window
Team Shepherd USA
Old 07-17-2009, 09:28 PM   #19
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I really don't know about that much nitro. I personally run 20% and have no need for any more.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-17-2009, 10:05 PM   #20
I used to run 20% & sometimes go back to it.Only place I can tell a difference is coming out of corners it hits a little softer & actually makes me faster.I have been told I was wrong by a couple people & right by a couple but my experience at least with the brand I use is the oil content is the same & 20% has more methanol(alchohol)that cools the eng & 30% has more boom juice to make more power(heat).Thats the way it works in my mind & at my fingers.I'm not one of those that leans to get a claimed 14 min run but with 20% I do lean to keep my temps in the range that makes power the way I like & its usually 1/3 to 1/2 a turn on top & a little less on bottom.Could be how you normally tune to begin with has an affect in what you get when you switch.
I'm not sure that with as over powered as most engs are these days that 45% would do anything but make it more difficult to drive.I see an unreal amount of wheel spin at almost every track I go to from all but the top racers & even from more than a couple of them.When I get good enough to manage the throttle as I would like then maybe I would look into 45% but really with as long as I've been racing & the level I have plataued at I dont see that happening,ever.Why not just put in a .28?
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 07-17-2009, 11:23 PM   #21
The way I see it, you can sacrifice power for fuel economy, etc. So if you use 45% nitro, you would counteract by getting a very small carb restrictor. ANd for all the bottom end, you can get carbon shoes/soft springs so your clutch lasts longer. RB doesn't make crap, that is a fact.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Logan Off Road ( The Brickyard ) Brisbane QLD BIG O Australian Racing 10325 03-08-2017 03:07 PM
GHL 1/8TH OFFROAD RACE dameetz Brunei R/C Racers 36 05-13-2009 02:24 AM
GS CUP Malaysia 2008 jets Malaysian R/C Racers 328 07-08-2008 08:40 AM
RCMC 2008 nitro series Kylelim Singapore R/C Racers 91 05-04-2008 08:35 PM
Massive 1/8th Offroad Nitro Liquidation ICE+ Futaba 3pk Spektrum SoCalTazer R/C Items: For Sale/Trade 45 12-09-2006 04:49 PM
2006 Chilean Nats, Jammin and Maxy's Fuel kills the competition !!! Tabushi Electric Off-Road 11 12-01-2006 06:45 PM
