Old 07-17-2009, 06:43 PM   #16
Gearhead racer's Avatar
Ive shimmed a box or two before adding some washers under the wheel unit where it mounts to the box.
Tyler
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 07-17-2009, 07:59 PM   #17
mudboger07's Avatar
If your new to starter boxes they can be a pain to set up, but it looksliek your ont he right track, you can also take a file to the wheel on each side to make the outer edge smaller to fit between the frame. just set the file against the wheel and start the wheel spining... this along with dremeling the edge of the opeing as said before will help...good luck....
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 07-17-2009, 10:10 PM   #18
sokar's Avatar
Originally Posted by butch man View Post
Those instructions linked a few posts above give a basic how to ,to eliminate your pushing,pulling,swaying problems. Also chamfering the chassis will help with that also.
What's that?
sokar is offline   Reply With Quote
Old 07-17-2009, 10:46 PM   #19
Whats what? Stopping your car from moving around on starter box?
See the pins sticking up from the top of the boxs? Those go in the armpits,where chassis & arms meet or as close to there as possable you gotta RIG sometimes.If your pins are installed correctly you should be able to toss your car on the starter & they will line your line your flywheel up perfectly over the starter wheel every time.The instructions for your box were linked by Pyromania 1/2 way down first page.
& for other style box...
As for the chamfer if you have the correct flywheel & pins are set up propperly you wont need it but all my cars get it anyway incase I have to use someone elses box & looks like this...
If your motor still has a lot of pinch the flywheel may still get stuck & using a screw driver to pry/rotate it is common till your motor is broken in(metal pinch goes away) then it should be a lot easier to start.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Why won't my Engine start? Burnz27 Onroad Nitro Engine Zone 7 09-18-2006 01:37 AM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 07:49 AM
new engine woes (novarossi rs12) packetdreamer Nitro On-Road 39 08-07-2004 09:14 AM
Need help making my nitro engine run psbarger Onroad Nitro Engine Zone 7 06-17-2004 10:51 PM
