Old 07-27-2009, 02:03 PM   #46
That was easy enough !! From now on just tear into it. You need to learn anyway and thats the only way to do it.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-29-2009, 07:18 AM   #47
elkman's Avatar
Default Not too much grease.
I would coat everything with a brush. Not too thick but enough to smear grease over the gears. I use white lithium grease on gears like that. I use synthetic lube on my 8ight in the differentials. I don't know if you could use that on yours. The case would have to be sealed completely. Make sure the gasket is still in good shape on the case where they bolt together. you want to keep dirt out of the gears or it will grind them down.
Looks like you are learning a lot already. Keep track of what goes where and don't over tighten the screws. it will strip the plastic. you might want to keep one of those output shafts as a spare because if it broke once, it will break again.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 07-30-2009, 10:24 AM   #48
Send a message via MSN to helgso
Default Strange sound
I just finished putting my RC together! However, there is a strange sound coming from the area where the transmission is at, or is it just normal?
I captured this video so you could see and hear. Am I safe to drive the car? Is the sound normal or is it bad?
http://www.filefront.com/14158179/StrangeSound.wmv
helgso is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
MST-1 Owners Post Here! StepPins Nitro Off-Road 1132 01-16-2016 04:39 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Saint Louis Carpet Racing!!! evostyle Kansas/Missouri Racing 1379 02-07-2009 08:11 PM
share your driving tips Version 2.0 cmain Electric Off-Road 33 08-01-2008 12:57 PM
