Old 07-17-2009, 01:50 PM   #16
Send a message via MSN to helgso
I took some notes of how the car ran. I started the engine, and while it idled, the pinions turned somewhat fast. So, the clutch works, all my pinions turned when the car was idling. Maybe you are right about the HI and LOW. Am I in danger trying to change those settings while the car is idling if my pinions are turning?
helgso is offline   Reply With Quote
Old 07-17-2009, 01:53 PM   #17
pyromania's Avatar
Trader Rating: 18 (100%+)
Just to be safe shut the engine down and switch it to the high option.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 07-17-2009, 01:55 PM   #18
elkman's Avatar
Default Try it with the engine off!
You should be able to select HI or LO with the engine off. Thats the whole idea of having a clutch so the engine can idle without turning the driuve system. If you try to select a range with it spinning you are likely going to eat up some gears. Shut it off, check the selector. start it up and try again.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 07-17-2009, 01:57 PM   #19
elkman's Avatar
Default Isn't the internet mind boggling?
We have a guy in Oregon, California and Czech republic helping a guy in Iceland! Fricking amazing!
****RUSH****
Old 07-17-2009, 01:59 PM   #20
True xD
Allright, is this the HI and LOW thingy?
Old 07-17-2009, 02:01 PM   #21
pyromania's Avatar
True xD
That should be the HI-LOW knob, but check your manual so you know which way to turn it.
Jesse Carrillo
Team Driver For:
Old 07-17-2009, 02:02 PM   #22
elkman's Avatar
Default Yes
True xD
And it looks like you are between gear selections. Look at the notches .You obviously have internet, You should go to the LOSI website and look at their electronic manuals
****RUSH****
Old 07-17-2009, 02:04 PM   #23
elkman's Avatar
Default Did you just take that picture?
Or is it an older one? if new, you dont have an intake air filter assembly or an exhaust. I dont think it would even run without an exhaust
****RUSH****
Old 07-17-2009, 02:07 PM   #24
It's an older picture, it's from the point of time when I was fixing the kit. I'll just try adjusting that knob, and let you know of the results.
Old 07-17-2009, 02:12 PM   #25
pyromania's Avatar
Read the manual before you even touch that knob.
Jesse Carrillo
Team Driver For:
Old 07-17-2009, 02:33 PM   #26
I just finished reading through my manual and it didn't even mention the Hi-Low selector, only in the parts list
Know where I could find information on this matter?
Old 07-17-2009, 02:35 PM   #27
pyromania's Avatar
google my friend
Jesse Carrillo
Team Driver For:
Old 07-17-2009, 03:42 PM   #28
Allright people, I surfed the internet and found a guy that had a LST2 that had the problem of that his LO setting worked and his HI did not. He described it as my problem sounds: The engine revs, but the car doesn't move.
Now, he fixed this by taking his transmission apart and replacing some things and tweaked some things. Here's the link to that persons problem and solution: http://www.rcnitrotalk.com/forum/showthread.php?t=39347
So I'm wondering, should I take my transmission apart and take a look at it?
Old 07-17-2009, 05:59 PM   #29
pyromania's Avatar
Have you even tried starting the truck yet? You sound really new to this sport, so I think you shouldn't even tinker w/ the transmission yet.
Jesse Carrillo
Team Driver For:
Old 07-18-2009, 05:56 AM   #30
coviello's Avatar
do what he did. call losi and have them tell you step by step what to do. that is if you want to drive the truck. or you can spend the extra money and take it to the hobby shop in your area.
coviello is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
MST-1 Owners Post Here! StepPins Nitro Off-Road 1132 01-16-2016 04:39 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Saint Louis Carpet Racing!!! evostyle Kansas/Missouri Racing 1379 02-07-2009 08:11 PM
share your driving tips Version 2.0 cmain Electric Off-Road 33 08-01-2008 12:57 PM
