Old 07-15-2009, 08:33 PM   #1
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Smart Diff Center T 2.0 Help
Installed and center smart diff setup front and back diff are stock roller setup running two .15 springs but the front tires are ballooning
bigjayjay1 is offline   Reply With Quote
Old 07-16-2009, 08:03 AM   #2
Stanton's Avatar
Sounds like you may have crushed the springs or they arent seated right. Take it apart and look close with a light and a magnifying glass. I had issues when I first started with the .15's and can tell you its easy to crush them. They are made to screw into the holes. Look close at them. One end is larger than the other.
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 07-16-2009, 11:37 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
This is how I rebuild them, it seems to work for me but the springs do have to be in the right spot.
What I do is assemble the sd on the bench, the plate that holds the spider gears then I put the gears in and pit the springs in and get them lined up I like to pit a little sd grease in the holes where the springs go. Once I am certain I have the springs lined up I set the assembly on the ramp plate and then top it with the other ramp plate. So now I have the whole assembly built on the bench. Next very carefully I lower the diff cup overthe assembley until it sits properly. Next I flip it over being careful to keep it all togeather and fill with sd grease. Last I place the gasket and ring or spur gear on top press it togeather and hold it togeather until I get a screw in it. Then I breathe. That's the way I have been rebuilding them and it seems to work pretty well for me. The rear diff is just heaven to rebuild now and I use to hate to rebuild the reg diffs. If you have a better technique or twist please let me know because I hate rebuilding these diffs.
Old 07-16-2009, 01:03 PM   #4
+1
SC8 - BCE - MRT GRP .21 - Factory Team carbon and aluminium options
SC10 - Nosram Matrix Evolution ISTC ESC - Factory Team options
Concept Racing Team Driver
plod is offline   Reply With Quote
Old 07-16-2009, 03:21 PM   #5
bigjayjay1's Avatar
Thanks for all the help I'll break down the diff using all the information provided.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
HPI Firestorm Official Thread. dracy69 Electric Off-Road 33 08-06-2007 12:46 PM
