Old 07-16-2009, 01:30 PM   #76
Originally Posted by Jaz240 View Post
Dreaux...pay attention to jamminkrazy's post about taking care of your engine!! After break in about 1-1/2 gallons..put TKO ceramic bearings in front and rear, and a new connecting rod..make sure you heat the engine EVERY time before you start it..get a heat gun or an engine warmer..no reason you cant get 10 gallons if you treat it right
truer words were never spoken,
ive invested in a home made engine heater and for my next engine i plan on using it all the time,
as for quality engine - ill stick my neck out and say novarossi, ive got a 367 with 4 gallons on it still cant turn it over when in the car and its going strong, doesnt cut idles all day and makes me smile.
Next on the list is a plus 4 but i wouldnt hesistate to get another 367!
Novarossi wins my vote
Megacrash is offline   Reply With Quote
Old 07-16-2009, 01:31 PM   #77
the ninja has 5 ports the vspec has 7 right?? Is this the main difference between the two?
jammin seems like you like you ninja better then your vspec. How bout your speed?
dreaux is offline   Reply With Quote
Old 07-16-2009, 01:34 PM   #78
i know this is a onroad engine but holly shit!!!! not just the price but almost 47,000 rpm's
http://www.amainhobbies.com/product_...ine-Turbo-Plug
Old 07-16-2009, 01:39 PM   #79
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
V-spec and SPEED are 3 ports. Ninja is 5. I love them all truly. The speed is linear monster. It has such a smooth, yet punchy powerband. The v-spec is the snappiest of the 3. It is less linear than the other 2. The ninja is kinda between the two. It is more linear than the v-spec, but not as smooth as the speed. They all produce around the same amount of power, just in different forms. The ninja and speed WILL outlast the standard v-spec because of the coated crank. For the money I would go with the ninja.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-16-2009, 01:40 PM   #80
Yeah, NO! Onroad engines are great for one thing onroad!
-Koby Kubrin-
Old 07-16-2009, 01:43 PM   #81
I would never put that in my mugen! i was just amazed at those numbers.
my losi re-11 will work good with the ninja?
Old 07-16-2009, 01:45 PM   #82
Yep it will be good.
-Koby Kubrin-
Old 07-16-2009, 01:46 PM   #83
JayL's Avatar
Yes,
And the Mugen has a better block than the v-spec
JayL is offline   Reply With Quote
Old 07-16-2009, 01:47 PM   #84
what do you mean by more linear? a smoother junction between bottom and top? from what you are saying it sounds like the vspec has the best bottom with the ninja having a better powerband is that right?
Old 07-16-2009, 01:50 PM   #85
i think i know what you mean. my vspec has crazzy bottom and screamin top with out to much in between. I mean a barely pull the trigger and it wants to go straight to the top.
although i would like a engine that would pull harder on the top
Old 07-16-2009, 01:56 PM   #86
Originally Posted by JayL View Post
Yes,
Agreed!
Not really that it has more bottom end, but the way it puts the power down is less linear. More like a light switch.
They both produce about the same amount of power, but the ninja puts it down in a slightly more linear, smoother way.
-Koby Kubrin-
Old 07-16-2009, 02:01 PM   #87
I am sold$ now i just have to find one. that is the other thing. They are pretty hard to find.
yeah my engine block on my vspec gets divets if you even look at it wrong.
the ninja sounds eisier to control with less spin outs
Old 07-16-2009, 02:04 PM   #88
http://carolinasrc.com/Webstore/Scri...dproduct=11957
On backorder like anyone else, but well worth the wait.
-Koby Kubrin-
Old 07-16-2009, 02:10 PM   #89
more ports means more top or is it the other way around. Can remeber if i am backwards or not.
Old 07-16-2009, 02:15 PM   #90
Typically that is correct. Even though it doesn't really apply for v-spec based engines. Just something about the design that promotes awesomeness.
Usually 3 ports are bottom end engines with no top end. 7 ports are top end monsters with little bottom end. 5 ports are in between.
-Koby Kubrin-
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Off roader thread Danny Teh Malaysian R/C Racers 6647 04-07-2015 02:57 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Aarcmcc Rules TrustMe Australian Racing 43 10-10-2005 01:15 AM
