Old 11-09-2009, 04:34 PM   #16
2fst2c's Avatar
Trader Rating: 114 (100%+)
Originally Posted by jeff alessi 801 View Post
What carb r u using the stock 1?
Yes until the last race. It started acting up and I swapped it to a new OS carb. Then Found out I had a pressure line leak and probably wasn't the carb. I've heard of people having problems with the stock carbs though. Mine worked good though.
2fst2c is offline   Reply With Quote
Old 11-09-2009, 04:42 PM   #17
2fst2c's Avatar
Originally Posted by sickboy View Post
the xray has a different gear ratio than the 801xt. stick with the 14t jeff, you are going to lose mileage if you go anything bigger.
Not sure what the difference is but I did go up 2 teeth and am going to go up 1 more from the stock 13t. Motor has a ton of bottom end and I want to see if it will still pull hard and get a little more top end speed.
Old 11-09-2009, 05:41 PM   #18
The engine is that powerful huh
jeff alessi 801 is offline   Reply With Quote
Old 11-09-2009, 06:24 PM   #19
2fst2c's Avatar
It is with the 2013 pipe. I tried the RE10 and an RB2045 and they were dogs. Orion told me to use the 2013 so I tried it and WOW! Get it broke and and watch the power come to life. You'll be amazed. It's almost as crazy as the .28XZ I ran before it.
Old 11-11-2009, 09:30 PM   #20
those 28s r pretty fast to compare to.
Old 11-12-2009, 10:14 PM   #21
What sirio or extech plug on amain would work with this engine since it's a star sirio type engine?
Old 11-13-2009, 03:46 AM   #22
2fst2c's Avatar
Not sure. I run OS plugs. P3,P5
Team Orion Engines pitpop Offroad Nitro Engine Forum 1900 06-06-2017 12:49 AM
New ORION ALPHA 3-PORT Marcus Falconie Offroad Nitro Engine Forum 185 06-20-2012 08:01 AM
