Old 07-16-2009, 11:33 AM   #16
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by Jaz240 View Post
Get the bumpstart backplate for the engine..I am not sure if it comes with the Hyper .21 engine or a macstar.
get a good starter box..
get a steering servo that has at least 200 OZ. in torque and move the steering servo included to the throttle
Get 2-4 extra glowplugs
It will come with a "good enough" glow ignitor, but you should upgrade sometime down the line to a rechargeable one.
You should get 2 1600+ MAH RX packs, and a decent pack charger..
Extra air filter foams..
After run and air filter oil
Diff oil, buy 5000 WGT, 7000 wgt, and 3000WGT..5 front, 7 center, and 3 rear...I think the Hyper comes with grease filled diffs and you want to change that..grease is for bashing..Diff oil is for racing
I believe it comes with the Hyper .21 (that is what the specs say.)
Starter box and battery(s)
Receiver pack
Rechargable (NiMH batteries) for the transmitter if you don't already have them.
Charger
Diff fluids
Shock oil (probably 45, 40, and 35. Those are "smaller bore" shocks even though they call them big bore, so the heavier 45 front 40 rear is probably a good starting point... can go down to 40 f 35 r)
Tools if you don't have them. (The OFNA will be all metric) 1.5, 2, 2.5, and 3 mm... and a long, thin bladed screwdriver for tuning the motor.
You are going to want some decent tires... the ones it come with are not going to be that great, and believe me, tires are THE BIGGEST change you can make to improve a car's handling. Without knowing your track it is hard to say WHAT to get, but look at what the local folks run.
And 7k center diff fluid is pretty heavy for a beginner. Try 5f 5c 3r to begin with.
If you have already got the spektrum system and are happy with the one you have... this car might be a better deal. The Losi IS still a superior car, but there is nothing wrong with a Hyper 7 for a beginner.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-16-2009, 11:36 AM   #17
Jaz240's Avatar
Trader Rating: 52 (100%+)
Here's a link for the backplate you will need to use the bump box..you can use it with the pullstart on..but not recommended"
http://www.nitrohouse.com/catalog/pr...ducts_id=13152
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-16-2009, 12:21 PM   #18
Trader Rating: 123 (100%+)
Are you basically removing the pullstart and pluggin the hole with this backplate?
Chris Gierse is offline   Reply With Quote
Old 07-16-2009, 12:51 PM   #19
Jaz240's Avatar
Remove pullstart, shaft, metal plate, and the one way bearing that looks like a fan, cover the whole thing with the new bump plate
Old 07-16-2009, 03:09 PM   #20
Gearhead racer's Avatar
This is what you'll need to get for the hyper 7 tq black.
-fuel
-AAs for the radio and receiver AA pack (12 total)
- 1 d cell battery for the ignitor
-extra plugs
-a heat gun to heat up the motor before to try to break it in. Motor is pretty tight.
- plug wrench
I think that's all you ll need and you'll wont be disappointed with this buggy. Then you can tell the losi guys to pound sand. opps....
Tyler
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 07-22-2011, 01:57 AM   #21
-fuel
-extra plugs
- plug wrench
Tyler
ive had the pico bugy for over a year, I had to replace all electronics seeing as they dont fit the bill.............. threw a rod my fault, but there wasnt a crack in the block so i put a new one in it still runs great im recently turning it into an sc truck because the ofna perform great and dont break.......... unles u dont have fail safe
kasper is offline   Reply With Quote
Old 07-28-2011, 03:56 AM   #22
ramjesr's Avatar
Get a Losi 2.0
ramjesr is offline   Reply With Quote
Ofna Truggy box help slaytanic Nitro Off-Road 41 02-25-2009 03:15 PM
HYPER 9.. How Far Away ??????? MadRacer Nitro Off-Road 57 11-01-2008 12:00 AM
Ofna Cd-3 penggoy Nitro On-Road 1551 01-14-2008 06:46 PM
Which brand? canadian_racer Rookie Zone 25 12-17-2007 07:39 PM
Tricked out Lightning Staduim Pro + parts reynolds716 R/C Items: For Sale/Trade 18 12-23-2006 07:35 PM
1/8 Offroad Buggy Mercury Racer Electric Off-Road 1510 12-05-2006 03:05 PM
