Old 07-20-2009, 08:38 AM   #46
p u s h!
ganymede is offline   Reply With Quote
Old 07-20-2009, 10:27 AM   #47
dlb
Go with the X-6 and buy a alu rear toe in plate and you are set for life .
dlb is offline   Reply With Quote
Old 07-21-2009, 07:16 AM   #48
omg! i think i found those 95% that are dead and speaking from the grave!
http://forum.teamxray.com/viewtopic.php?t=9467&start=0
read up those posts that mentioned the pinion bearings...
to those that are considering the 808, there are plenty of pros and cons there as well, very informative!
Old 07-21-2009, 07:47 AM   #49
Trader Rating: 19 (100%+)
The 808 is indestructible. The only issue I had with mine was the bearings and it is because they use a smaller bearing size for less rotating mass. However, this can be easily fixed by spending $10 to purchase standard sized bearings. I put a set of avids in my car several months ago and have not had a single blown bearing. Honestly, the bearing issue wasn't even that big of a deal. Just had one blow on the center diff and I am running a high powered brushless setup too.
Most stuff on the 808 doesn't break. The arms will warp after about 5 months of use though.
I have had the car almost 8 months now and never had single DNF related to a part breaking or failing on my car. I haven't broken anything except a front diff housing and shock tower after I hit a brick wall going about 40 mph head on at full throttle.
Quite frankly, all the other brands are let down in the quality department after owning this car. I am not saying it is the best driving or handling car and will instantly put you on the podium, but I am saying that you will not be disappointed one bit from a durability and quality standpoint.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 07-21-2009, 04:18 PM   #50
mugen will not let you down in the quality department. to say otherwise is just blasphemy.
dreaux is offline   Reply With Quote
Old 07-21-2009, 05:54 PM   #51
wat about the bent chassis of yours?
Old 07-21-2009, 07:36 PM   #52
captain america's Avatar
You can bend the chassis on any car by placing just a bit too much stress in the right place; the 808 is no different from any other buggy in that it does not respond well to continuous lawn-darting
captain america is offline   Reply With Quote
Old 07-22-2009, 02:22 AM   #53
Old 09-03-2009, 09:39 PM   #54
turbo250r's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to turbo250r
Default mbx6 rear toe plate
can anyone tell me where to get a aluminum rear toe plate besides m2
mugen:::
mbx6
mbx6t
turbo250r is offline   Reply With Quote
Old 09-03-2009, 09:43 PM   #55
Fioroni or however its spelled have one & not sure on kingzhead but they do or will make most parts for most cars with very little nudging.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 09-04-2009, 01:03 AM   #56
dlb
Fioroni have one as above mentiond you can get it att a main hobbies.
Ghea Racing has one too. However im not allowed to post urls yet.
I use the Fioroni one becouse Ghea had not released one back then.
Ghea is about half the price but a main is super easy and deliver fast.
Old 09-04-2009, 01:28 AM   #57
gameholic2's Avatar
I honestly believe that most people that are not biased and owned both cars Will say the Mbx6 is the better car in terms of handling and reliability.
I was a die hard Losi fan, got the 2.0 when it first came out, drove it liked it until i purchased an Mbx6 didn't realy like it at first cause i probably got used to the twitchy Losi handling but when i got the proper set up on the 6 I was much much faster and consistent...
decided to try the 808 and after missing the A main for three consecutive weeks due to bearing failures I went back to the 6 and the 808 is collecting dust...
like i said in the beginning, most people that got the chance to own the 6 and an 808 will prefer the 6.
gameholic2 is offline   Reply With Quote
Old 06-09-2010, 07:19 AM   #58
mariano2cv's Avatar
Some of you may say otherwise?
mariano2cv is offline   Reply With Quote
Old 06-09-2010, 07:28 AM   #59
OTD!
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
Old 06-09-2010, 07:36 AM   #60
mariano2cv's Avatar
OTD!
my English is very limited you may be more clear please
