Old 07-16-2009, 05:38 PM   #31
No pinion or pinion bearing problems on my 08-808 either in 16+gal.I do change pinion bearings about every 4 gal or so & grease them every couple gallons-ish.I was at a play day & heard my front diff whine badly from forgetting to put shims(0.4mm) back on after changing fluid & didnt ever bother to pull off & install them,I knew it wouldnt damage Hudy steele gears,that kind of confidence is one of the reasons I run the 808. I do replace outer wheel bearings more often than I would if they were 8X16 but $4 in bearings every few gallons is a small price to pay for what I think is the only short coming of the car but all MFGs are turning to smaller "ball" style bearings these days, too bad to cuz I dont like that trend. As for pivot balls & rod ends Mine have less slop at over 8 gallons(were replaced once at first 8 gal)than my losi did out of the box & about equile to my mugen 5r & 5t at about 4-5 gallons.
butch man is offline   Reply With Quote
Old 07-16-2009, 10:41 PM   #32
Originally Posted by Semple View Post
That bearing issue has never been a problem for me. I just ground down the tip of the CVD where it meets the centre diff by about 1-2mm, and lengthened the slots on the centre diff cups also about 1-2mm. I have never replaced those bearings... I still have the 08 setup without the collar.
any photos?
ganymede is offline   Reply With Quote
Old 07-17-2009, 02:37 AM   #33
Just do a search for Xray 808 bearing failures. It's like the tobacco companies in the past saying smoking doesn't cause cancer. Sure 5% of smokers are okay and they speak up but what about the other 95% that are dead. Oh yah, I'm back from the grave telling you my story.
Toycar5 is offline   Reply With Quote
Old 07-17-2009, 05:56 AM   #34
Originally Posted by ganymede View Post
any photos?
I'll take a couple after work. Probably just post them in the 808 thread. But like I said, I haven't had bearing failure. Not before and not after the slight modification of the shaft. Another driver at the track told me to do it just in case. The 808 has tons of flex and will fold up like a taco(in a good way) and I guess the theory was that it bottoms out the pin in the outdrive slots and that's when the bearing damage is done on the other end of the cvd. Apparently it has solved a few 808 guys' bearing problems around here.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 07-17-2009, 08:40 AM   #35
interesting! i wonder what will those forumers in the 808 thread gonna to say about this...
Old 07-17-2009, 08:48 AM   #36
Jaz240's Avatar
Trader Rating: 52 (100%+)
I am one of those forumers, and I'm not dead either..I built my 808 box stock according to the Manual..No mods at all, just some set-up changes, no grinding, no sanding..Except for the center diff plate (to make more room for my throttle link) I did put the spacers in my bulkheads when they were released a few months back, but so far I have about 10 gallons on my 808 since last October and have not had 1 problem with any bearings or drive train..The only think I find to be a pain in the butt is that the engine lines up on an angle to the center diff. Its not straight and meshing my gears after removal of the 2 piece mount is a pain in the AZZ!!!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-18-2009, 01:51 AM   #37
i met a few that said the 808 is problematic and needs lots of maintenance, on the other hand there are those like yourself and those wonderful folks in the 808 threads that said otherwise... this is getting confusing! i guess the only to way to clear that up is to actually build and race one...
Old 07-18-2009, 07:40 AM   #38
Good idea!
"TEAM TERRIBLES"
Old 07-18-2009, 08:12 AM   #39
I love the 808 BECAUSE it is low maintenance. My only problem to date was front shock towers. I have split the carbon fibre and ruined two of them.
Old 07-18-2009, 09:36 AM   #40
did u seal it with CA before running them?
Old 07-18-2009, 11:02 AM   #41
xlgraphicspro's Avatar
Add me into that 5% category. I still have the old bulkheads, and no spacers in my 08 xb808. Not one bearing blowout resulting in a DNF to date. The Car is a tank disquised as a F1 race car!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 07-18-2009, 11:39 AM   #42
Jaz240's Avatar
My guess would be that people telling you they are high maintenance and problematic are not people who own one!!! XRAY took the best of all the new buggies and made it better and then released it..Its built like a tank, fast as hell, jumps like a Gazelle, and turns on a dime..The only slop after 10 gallons was new drive pins, center diff outdrive cups and tighten up a few screws..All other parts parts on my buggy are still the originals. (except for some severe crashes that did break stuff)
Old 07-18-2009, 12:15 PM   #43
Yep. I think it may have just been the CA I used not being very good. I have never seen anyone else with an 808 have the same issue with the towers.
Old 07-18-2009, 09:43 PM   #44
I sanded & CAed mine & while notactually damaged the tops are ground down to an angle from sliding upside down too much
"TEAM TERRIBLES"
Old 07-19-2009, 03:05 AM   #45
i hav to admit that i am on the same boat as with the thread starter, trying to make up my mind on whether to get a 808 or a mbx6. one thing for sure is that i am currently swinging toward 808 based on all those wonderful comments by those in the 808 threads. mbx6 also has it fair share of excellent comments and reviews and i believe both are very capable cars, it all boils down to personal preference and of course the all important parts support.
