Old 07-14-2009, 03:33 PM   #16
Trader Rating: 36 (100%+)
Originally Posted by Jaz240 View Post
......and try to get it all in one post
Be nice...he had what we here in the NE call a "Giorgi" moment :P
NitroOB4You is offline   Reply With Quote
Old 07-14-2009, 04:38 PM   #17
beginner4life's Avatar
Trader Rating: 9 (91%+)
Checked the clutch, shoes are fine.
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 07-14-2009, 04:47 PM   #18
Jaz240's Avatar
Trader Rating: 52 (100%+)
springs? bearings? endplay? mesh? flywheel? collette?
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-14-2009, 04:48 PM   #19
vladconnery's Avatar
Trader Rating: 35 (100%+)
Had the same engine. Now that you have passed the gallon mark the engines needs have changed (tune) as mined did. This engine is now ready to show you its has balls. RB's inherently like to be slightly rich on the bottom end. Get the bottom end straight first. Please don't ask the question how many turns from this or that position because every engine is as different as finger print.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 07-14-2009, 05:24 PM   #20
but what about the fact that it won't idle?
*Team Terribles*
Old 07-14-2009, 05:38 PM   #21
LRHHOBBIES.COM's Avatar
Default Ron Paris Knows
Ok so instead of explaining what you need to do. Click on the link and basically memorize everything in the article. The article is long but worth the time it takes to read.
If you do not know who he is, Ron Paris is probably still the best tuner to have run nitro. He is no longer around but his work still teaches many.
I have lived by his tuning guide and it has never steered me wrong.
Ron Paris tuning guide.pdf
LRHHOBBIES.COM is offline   Reply With Quote
Old 07-14-2009, 05:49 PM   #22
wingracer's Avatar
Trader Rating: 23 (100%+)
Have you tried some fresh fuel? Running rich AND hot with a bad idle is classic moisture in the fuel problem.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-14-2009, 07:25 PM   #23
It's about 2 months old...
*Team Terribles*
Old 07-15-2009, 02:34 PM   #24
tried new fuel, and seemed to lower temps to normal, but still idles less than 5 seconds, it is making tons of power. Could bottom end be too lean?
*Team Terribles*
Old 07-15-2009, 02:37 PM   #25
Jaz240's Avatar
Yes, or too rich, how is your throttle response.when you pull the trigger is it snappy and fast or boggy and slow..Read the tuning bible on the top of the Off road section that will really help you get a handle on how to tune your engine.
What happens when you pinch the fuel line?
Old 07-15-2009, 02:55 PM   #26
Thanks a ton for all the suggestions guys. After about 3 hours of checking everything, trying different tunes, i got it going well, it was a mixture of bad fuel and me messing up the tune because of the bad fuel.
*Team Terribles*
Old 07-15-2009, 03:48 PM   #27
Glad to hear you got it fixed.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 07-16-2009, 08:17 AM   #28
Joey Powell's Avatar
Originally Posted by imaxx21 View Post
so you have smoke and it sounds good?
throw the temp gun the trash, and race
Truth
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
