Old 07-14-2009, 06:17 AM   #1
Default odonnell truggy question
had the rear diff ring gear and pinion gear shaft strip out on me i did shim it according to the manual i used two shims on the pinion and 1 on each side of the diff cup outdrives has anyone had this happen or how you shimmed it will help thanks
twayne81 is offline   Reply With Quote
Old 07-14-2009, 06:25 AM   #2
Troy Pinkston's Avatar
Shim the diff tight as possible, you may think to yourself its way to tight, but will break in and be fine. IMHO you def need more than 2 shims. I think currently I have a thick with 2 thins on one side and 2 thins on the other. I like it tight. They always break in....
Troy Pinkston is offline   Reply With Quote
Old 07-14-2009, 04:41 PM   #3
thanks for the advice troy and by no means am i calling you wrong but just seems a little excessive but i would like some more opinions the truck ever since i built it has roughly 3 tanks and not a super powerful engine and even after i took it apart the shims were correct from the manual i already have new parts but was wondering do you think i got bum parts or should i shim one side more then the other or if troy is right (im sure it works for his truck)but any other ideas would be appreciated
Old 07-14-2009, 04:57 PM   #4
I had the same thing happen on my Z01-B. I shimmed it to the same resistance as my Kyosho and Turmoil had and ended up blowing out the ring gear about 4 tanks in. For the replacement I shimmed it pretty tight. It loosened up after 4 or 5 more tanks. I'm now well into my second gallon and the diffs are still perfect.
mthird is offline   Reply With Quote
Old 07-14-2009, 04:58 PM   #5
BTW, TP is one of the (if not *the*) top factory drivers for OD
Old 07-14-2009, 06:08 PM   #6
iglu25's Avatar
Trader Rating: 14 (100%+)
Like Troy said, run them tight! Very, Very, minimal play in the gear mesh. They will break in and be smooth as glass...
Castle Creations/TLR/Horizon/Proline/Avid/DIALED INC./Venom Batteries
iglu25 is offline   Reply With Quote
Old 07-14-2009, 06:32 PM   #7
thanks for the advice i will try it and let you guys know what happens
Old 07-14-2009, 08:23 PM   #8
Devilbrad's Avatar
My rear diff took two thicks and one thin on ring side, front took 2 thicks on ring side and 2 thin on other sides. The manual doesnt say use two, it shows a picture with just two, but under that it says "The number of shims needed, and the side on which they must be placed, may vary." Make it tight. Steve O'Donnell told me as tight as can be and still smooth and use three evenly spaced 3/4" long strips of black grease, then after initial run in, regrease it.
O'Donnell Z01-T, OS 28XZ, T-2060SC.
Associated RC10T, Peak Performance 15T, Novak electrics, 17 years old, and beat to death.
HPI Blitz, bone stock.
TCS Edge crawler, Tekin 35T and FX-R ESC.
Yokomo MR4TC BD, no electronics.
Devilbrad is offline   Reply With Quote
Old 07-14-2009, 08:44 PM   #9
aaron joy's Avatar
Trader Rating: 16 (94%+)
You do know there is two top factory drivers for O'Donnell that share the initials TP.
Taylor Peterson and Troy Pinkston
aaron joy is offline   Reply With Quote
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
