Old 07-14-2009, 10:35 PM   #16
sperera's Avatar
Ok I will do that, Jeez im glad I joined this site, these break in instructions are vastly different to what I was going to follow which I received from another site.
With the buggy on a stand wont it heat up too much because there will not be any air flow? Would it not be better to put it under some load and take it on a smooth flat surface?
sperera is offline   Reply With Quote
Old 07-15-2009, 04:37 AM   #17
Gearhead racer's Avatar
You can do it that, just you'll need to adjust your idle so the wheels don't start to spin at i really high rpm. You also can set it on the ground against something and let it go. Or you can put on the ground and run it around. Everyone doesn't do the breakin the exact same way.
Tyler
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 07-15-2009, 05:28 AM   #18
Now this is the sticky topic no matter who I talk to about break-in. Me personally, I do not idle nothing, from the first tank, I put my car on the ground and run it, 1/4 throttle, but I always make sre that it reaches 200 degrees.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-15-2009, 05:31 AM   #19
cluffy1's Avatar
Default hay
what i did was i when on to youtube and type in squirrelod. and whento his breakin videos. this will give you everything you need to no including showing how to do it and what it deos. he will also give you three different methods on how to do it. VERY DETAILED.
vid 1= http://www.youtube.com/watch?v=pAggkhHqEkw
go hard or go home
cluffy1 is offline   Reply With Quote
Old 07-15-2009, 04:17 PM   #20
sperera's Avatar
Awesome, ill jump on youtube tonight and see if I can get any more pointers. I am feeling allot more confident now about breaking in my new buggy, wont have time to start until the weekend though.
