Old 09-12-2009, 10:32 AM   #31
8&stuff's Avatar
Trader Rating: 55 (100%+)
Originally Posted by miket3 View Post
mine is the red/yellow one at rochester.
thats the one im talking about lol. seriously dangerous. you sweep that track nice
Mark Buecker
8&stuff is offline   Reply With Quote
Old 09-13-2009, 03:42 AM   #32
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
I have been playing around with my setup for the BCE Chassis alot
this is what i am now running
I use the same setup on my Stock chassis aswell and its dialed. but the BCE makes a massive difference
Ride Height
Front = 38mm
Rear = 43mm
Droop
Front = 107mm
Rear= 128mm
Sway Bars
Front = 2.3mm
Rear = 2mm from buggy kit
Springs/Shock oil/Pistons/Location
Rough Track Front = black / 35wt / 55 / Middle on tower & Middle on arm
Rough Track Rear = white / 32.5wt / 56 / Out on tower & Middle on arm
Smooth Track Front = black / 32.5wt / 55 / Middle on tower & Middle on arm
Smooth Track Rear = white / 27.5wt / 56 / Out on tower & Middle on arm
Diffs
Front Diff = 7k
Rear Diff = 3k
Center-diff= 10k
Gearing/flywheel
Clutch= Losi Steel flywheel, 2 carbon with gold springs 2 MaxLife with silver springs
Clutchbell/spur gearing= 13/50
Toe/Antisquat
Front = 5* Out Total
Rear = 2.75/3
Losi adjustable toe blocks. Running all 0's in the front block set. 1's up in the forward rear block, 0's in the back rear block.
Camber
Front = -2
Rear = -3
Tire and Wheels
AKA's, Losi/GRP's and Prolines with GRP foams
Chassis, body and wing
chassis = BCE Speed
body = stock
wing = Team Associated RC8
Electronics/Battery and Battery Placement
stering Servo = Hitec 7955TG
Throttle/Brake servo = Hitec 7955TG
Battery = 2300mAh Intellect Lipo No regulator
Electronics = Sanwa M11X
Engine/Pipe/Plug/Fuel
motor = RB C6BBT L2G / RB WS7III L2G
Pipe = RB 2045 with 198 header / Thunder Tiger 2035 with OFNA long header
Plugs = Odonnell 99T
Fuel = NitroX Barmah Blend 39 30%
Camber Links, Hubs
front = 2 / A
rear = 3 / B
hubs = 1 spacer each side
Track Conditions. Hard pack, large jumps, various bite
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
