Old 07-13-2009, 10:05 AM   #1
Default strange question about screw size
what size is the set screw the is in the end of an OS pipe. the screw i am looking for is the screw that secures the pipe wire at the end of the pipe
quicklosi is offline   Reply With Quote
Old 07-13-2009, 10:15 AM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
Not sure about OS. Most use a 4mm set screw. Some use an even bigger one, 5mm I think.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-13-2009, 10:18 AM   #3
jpz_67's Avatar
Trader Rating: 56 (100%+)
3mm x 3mm cup point socket set screw.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 07-13-2009, 11:07 AM   #4
RCmayor's Avatar
Send a message via Yahoo to RCmayor
3mm is pretty small for a pipe mount, 4mm is the smallest I have seen and it is most likely 5mm.
RCmayor is offline   Reply With Quote
Old 07-13-2009, 11:14 AM   #5
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
i would go with what the os team driver told you it a 3 i am pretty sure
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 07-13-2009, 11:30 AM   #6
jpz_67's Avatar
Not a team driver, I cant take any of that credit.
I have a 2060 on my buggy and the setscrew takes a 2.0mm hex driver, in general most of your rc fasteners that take a 2.0mm driver are 3mm in thread diameter, with the exception of a socket head cap screw. They take a 2.5mm driver, along with all the 4mm flat socket screws on the bottom of your chassis.
Old 07-13-2009, 11:58 AM   #7
RCmayor's Avatar
3mm set screws use 1.5mm drivers, 4mm set screws use 2mm, 5mm set screws use 2.5mm.
Old 07-13-2009, 02:57 PM   #8
jpz_67's Avatar
You may be right, those tiny set screws get me sometimes. I will double check when I get to the house. Too many numbers going through my head at work.
2008 SINGAPORE INVITATIONAL GP ONROAD CHALLENGE X4 Singapore R/C Racers 109 07-21-2008 04:32 AM
