Old 07-12-2009, 09:38 PM   #1
Tbstr3's Avatar
Send a message via AIM to Tbstr3
Questions?? TRX .15 enigne troubles
ok im sure you guys heard this one before i may be repeating sorry if i am just send me the link if you got it
Well i set all my needles to default setting have new glow plug new fuel and still having some issues everything is fine once the engine gets going (high end) but there is just no power at low end like taking off i got nothing its like its geared extremly high (its not off course) do you think i have a air leak or could my low end needle not be adjusted right. ive tried adjusting high speed needle but thats not where my power is missing
my needles
high end needle i start out at 2 and 1/2 turns out
low end needle is 1 and 3/4 out
idle speed screw about 1mm gap
im gonna pull engine out tommorow and check for leaks with soap water im just looking for some tips coming from someone with experience with these shitty engines lol
Slash is uncontrolably fast !!!!
Tbstr3 is offline   Reply With Quote
Old 07-12-2009, 09:41 PM   #2
Sounds to me more like a clutch issue and if u havnt replaced the clutch shoes and springs in a while in a while its probable worn out and that will deffinetly cause low end bog.
[Serpent America|Novarossi|Desoto Racing|Ridgeway Bodies]
crazy 8t is offline   Reply With Quote
Old 07-12-2009, 09:43 PM   #3
Tbstr3's Avatar
is there a way to check them i have another engine sitting here i could just swap em out?
Old 07-12-2009, 09:45 PM   #4
See ya u could do that but unless u know how old the shoes on the other engine are u could be replacing them with another bad set in my opinion the best thing to do is throw down some cash and go buy a new set that way if it still bogs after that u can weed things out from there
Old 07-12-2009, 10:07 PM   #5
Tbstr3's Avatar
its kinda odd just doesnt seem right you think the clutch is engaging to quickly or somthing? i mean it is kinda like its starting out in 3rd gear but doesnt it have to engage right away for it to take off. I might have worded it wrong basically i floor it watch the carb open all the way but the speed gradually increases ill take it out again tommorow check for leaks and reset all my needles little tight on funds till the weekend so i may sway clutch shoes just for kicks and see what happens
Old 07-12-2009, 10:17 PM   #6
Yes the clutch is ingaging way to quick or no where near enough because of how worn it is
Old 07-13-2009, 09:44 PM   #7
Tbstr3's Avatar
Lightbulb
ok i got into engine tonight and swapped shoes i also found the o-ring on the bottom of carb to be bad and another thing im wondering if anyone seen before this engine has a hole in botttom of carb (pictured) and a fitting for fuel or somthing my old engine did not have this so i switched to my old carb and pin ive attached pictures it looks like it was another fuel inlet/outlet not sure cant find anthing for traxxas part number either way it was a major air leak!
Old 07-13-2009, 09:46 PM   #8
Tbstr3's Avatar
i will run engine tommorow night to see where we stand here but wh knows lol
Old 07-14-2009, 06:05 AM   #9
Tbstr3's Avatar
morning bump anyone know why that port is on there? and hole in carb
Old 07-14-2009, 01:17 PM   #10
Tbstr3's Avatar
