Old 07-12-2009, 07:48 PM   #1
shipwama's Avatar
Default A good question
Hello, so i have been having low end bogging problems with my motor, i have leaned and richened my motor on both top and bottom end and had experienced people try to tune it for me with no avail
so i got to truoble shooting, no leaks, clutch shoes felt good
i got to looking and the clutch shoes are in backwards so as i look at the engine form the front so i can see the clutch straight on the shoes are hinged on the right hand side which woul make them a leading edge,
the question is, could that be contributing to my bogging problem?
thanks in advance
i have another thing i know is contributing, and that is the shoes are in backwards, there is a thin side and a fat side so the spring is making the shoes ride up on the posts causing the side of the shoes to rub against the clutch
but could the wrong way clutch be also contributing?
shipwama is offline   Reply With Quote
Old 07-12-2009, 07:57 PM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
100% yes installing the clutch that way will make it grab harder and sooner that will cause the engine to work harder and bog. Install the shoes such that when the engine spins counterclockwise the shoe trails behind the pin. The clutch has everything to do with a bogging problem. Install the clutch shoes correctly and the problem should correct itself.
Old 07-12-2009, 08:00 PM   #3
shipwama's Avatar
i sure do hope your right
Old 07-12-2009, 08:38 PM   #4
8&stuff's Avatar
Trader Rating: 55 (100%+)
clutch
Mark Buecker
8&stuff is offline   Reply With Quote
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
JL EVO 3 "TUNED" Team Kamikaze Onroad Nitro Engine Zone 396 07-01-2014 09:03 PM
Fusion Batteries John Malin Team and Company Discussions 1827 05-15-2013 08:48 PM
dish wheels mark123 Nitro On-Road 13 07-30-2004 01:26 AM
Is EP in ? pokemon Malaysian R/C Racers 922 05-12-2004 11:05 PM
