Old 07-12-2009, 04:07 PM   #1
Default who makes the best suspension??
Just curious as to who has the best shocks. I know they are all good, but i thought this might be a interesting discussion. If i had to guess i would say kyosho or associated?
Does ferronni make shocks
dreaux is offline   Reply With Quote
Old 07-12-2009, 04:09 PM   #2
Trader Rating: 2 (75%+)
i like the associted an jammin big bores
cjhorne is offline   Reply With Quote
Old 07-12-2009, 04:12 PM   #3
the ones on the new tamiya 801x look fricken spectacular!
Old 07-12-2009, 04:34 PM   #4
dandrat's Avatar
they are nice and tamiya is well known for there shocks.these days i think all the major manufacturers are pretty even though.
dandrat is offline   Reply With Quote
Old 07-12-2009, 04:48 PM   #5
When it comes to shocks nowadays, especially with 1/8th scale or truggy shocks I like to look at the way the lower seal is designed. Using c clips on current big bore shocks is asking for possible problems in the long run. I like the D8 style shocks, they went together without any problems and love the way the seal is retained. I've seen the mugens too, and they have a similar seal retention system too. I've run the ST-RR big bores and didn't care for them cause although they are smooth, the c clip retainers aren't as reliable to me in the long run as other designs available.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 07-12-2009, 07:46 PM   #6
Devilbrad's Avatar
I'm new to the modern RC tech (just back into it after 15 years), just put together my O'Donnell truggy, it has snap rings in the shocks. I guess thats what you guys are calling c-clips. What do the other shocks use? One way to make snap rings/c-clips stay put is to look at them before installing. One side is rounded on the edges from the way they are stamped during manufacturing, other side is flat and has sharp edges. The sharp edges should always go towards outside of the hole you are installing them in. Just something I learned working on full size race cars.
O'Donnell Z01-T, OS 28XZ, T-2060SC.
Associated RC10T, Peak Performance 15T, Novak electrics, 17 years old, and beat to death.
HPI Blitz, bone stock.
TCS Edge crawler, Tekin 35T and FX-R ESC.
Yokomo MR4TC BD, no electronics.
Devilbrad is offline   Reply With Quote
Old 07-12-2009, 08:11 PM   #7
It's kinda hard to explain how the hot bodies shocks and the mugen are. There's a cap for the lower end of the shock that has a hole that the shaft passes through. This cap, threads onto the lower end of the shock and retains the orings and plastic guides that are comon in shock seals of most r/c shocks. For me, for the seal to blow out would be less likely than that of c clip retained shocks. Especially over time, the newer shock cap retained seals would be more likely to survive longer without failure. If you look at hot bodies website online, you can look at the D8 or D8T instructions and can see how their system works. A friend was putting together a MBX6T and the shocks are similar in the seal retention to the HB big bores. It's not that a C clip design is lacking in performance, it's just one less thing that has a chance of going wrong with a newer design.
Old 07-12-2009, 08:21 PM   #8
8&stuff's Avatar
Trader Rating: 55 (100%+)
the best shocks are the ones that were either just rebuilt or bought. shock maintnance is key for any shock on the market
Mark Buecker
8&stuff is offline   Reply With Quote
Old 07-12-2009, 08:26 PM   #9
Devilbrad's Avatar
I gotcha, that does sound like a better design. Less parts, less failure.
Old 07-12-2009, 10:45 PM   #10
rcgeezer's Avatar
I've recently installed the TQ racing shocks on my ST-RR and they work flawlessly! As it turns out TQ fashioned many parts of thier vehicles after Kyoshos, so the shocks were almost interchangeable. The nice thing is that they have threaded collars, so no more funky plastic spacer rings to control ride height!! And no c-clips or snap rings either...just a simple combo of o-rings, spacer and threaded cap. I'm very happy with the way they work
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 07-13-2009, 04:50 AM   #11
Default Mugen started it all
Mugen started the trend of using all the screw on bottom caps. Matter of fact Mugen changed the way shocks are built back when they released the MBX5T/5R. These were not Big Bores but jammin wasted no time copying the shocks and making them big bores. All modern day shocks with the exception of a hand full copied the best design. So lets give props to Mugen for making the best shocks...
oneflyryd is offline   Reply With Quote
Old 07-13-2009, 06:14 AM   #12
tristyn's Avatar
Default SHOCKS
The new Jammin super big bores work great. There is a cap on the bottom of the shock body that threads on to retain seals with a hole for the shock shaft. I have yet to have one fail.
tristyn is offline   Reply With Quote
Old 07-13-2009, 07:10 AM   #13
Frank L's Avatar
Trader Rating: 148 (100%+)
What no vote for losi? Yes the new truggy roller came with incorrwctly installed shock ends but the shocks are very close to the 1.0 shocks and I ran those all last season no leaks no problems. So far this season on the 2.0 I had the poor factory build to begin with but over all they have worked very well. I like a soft suspension so 27.5 and 32.5 oil works well for me. The losi shocks are put togeather just lke the mugen with the usual seal and plastic guides and a screw on cap. This is a great design.
Old 07-13-2009, 07:40 AM   #14
Lonestar's Avatar
if you want to go this way, props to Tamiya, really. In 1986, tamiya was the first manufacturer to use screw-on bottom caps on their (in)famous and legendary yellow CVA's, enclosing two o-rings as well as plastic guides, and first released on The Fox. Almost everyone's copied them since, barring the odd american manufacturer (AE and Losi, namely) in every category, 10th scale offroad, onroad, 8th scale onroad, offroad...
Give credit where credit is due
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 07-13-2009, 08:20 AM   #15
Frank L's Avatar
Paul
I used to have a fox and a falcon. What memories.
Kyosho Inferno VE UK.hardcore Electric Off-Road 95 08-29-2010 08:22 AM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 08:22 PM
Building my first real competitive car. yzracer758 Electric Off-Road 6 04-08-2008 10:51 AM
No Limit R/C-Dennis Anderson's Halloween monster truck bash at Digger's Dungeon No Limit RC Monster Trucks 20 11-08-2007 11:27 PM
How best can new gal driver get started?? Mini Singapore R/C Racers 43 08-25-2007 12:16 PM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 09:50 PM
Ofna Ld3 che Nitro On-Road 160 06-01-2003 07:07 PM
