Old 07-12-2009, 03:26 PM   #1
Default Air Filter
Has anybody used the RB Concepts 2 stage air filter and if so how did they work, also who makes a good 2 stage filter. I will be using it on a Truggy in really dusty conditions. I did a search and couldn't find any info.
Thanks in advance!
TNHEADDUCK is offline   Reply With Quote
Old 07-12-2009, 07:02 PM   #2
Should work fine in a truggy just expensive is all & for buggy there hard to fit,realy huge filter. I would suggest if you run buggy now or will soon find a smaller filter to start with but the quality of the RB is good.
butch man is offline   Reply With Quote
Old 07-12-2009, 08:19 PM   #3
I ran the RB two piece in the past. It's not bad, but a bit heavy compared to the all plastic ones available. Also, if you run the rb, make sure to use a sealant on the base of the filter to seal the aluminum center to the plastic side.
To be honest, I'd go with one from mugen or proline. They're cheaper and as long as you use a good element, they will perform just the same as the more expensive RB unit. I've run the Mugen one from the MBX buggies with RB filter elements with good results for the past 4 years or so. RB's filter elements are really good, just be sure to oil the inner up well.
good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 07-13-2009, 06:09 AM   #4
I was thinking that with the star cut or whatever you call the shape of there filter it would give me more surface area to filter with, Iwas going to use my Mugen housing and put there element in it.
jason
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Question on Air Filter Oil Ken4 Nitro Off-Road 9 04-16-2008 03:59 AM
