Old 07-12-2009, 02:47 PM   #1
Default Gearbox problem
Hey guys!
I just took my kyosho DBX for a spin and I hit a bump at medium speed and the car flipped. When I flipped it back I noticed that pushing the throttle increases rpm but car does not move and I heard clinging in the gearbox. I also noticed that the air filter poped out. I stalled it (accidentally pulled out the fuel pipe ) wiht pliers and took it home. here is a vid after taking the gearbox on and off:
http://www.vimeo.com/5566051
Please tell me if there is still anything wrong with it.
P.S. Any1 know how I could have gotten fuel/grease/oil on the flywheel and air filter?
Nikzilla is offline   Reply With Quote
Old 07-12-2009, 03:16 PM   #2
nobody wants to help
Old 07-12-2009, 03:27 PM   #3
The only way for you to figure all this stuff out is to take it apart and see for yourself if something is wrong. There is really no way to diagnose all your problems on a computer. Open the manual and get to work !!
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-12-2009, 03:36 PM   #4
touk it out forgot about da manual
Old 07-12-2009, 03:48 PM   #5
can u at least tell me if it should be making that sound or if I have to take it apart and try and fix it?
Old 07-12-2009, 06:16 PM   #6
bump
Old 07-12-2009, 06:53 PM   #7
bump
Old 07-12-2009, 08:05 PM   #8
ok I figered it out. It was the back brakes, the screwes shifted so that the brake was apllied at idle. QUICK QUESTION though:
With the brake adjustments as in the manual, the back brake locks at full brake, but the front only slows down the diff. is that supposed to be like that or should I tighten the front to make it lock?
Old 07-12-2009, 08:28 PM   #9
Jaz240's Avatar
Trader Rating: 52 (100%+)
Racing or bashing? Racing you want the rear tires to brake slightly harder than the front, but not lock up as this will cause you to skid and loose control. If you are just bashing it dont really matter, but you still want some front braking
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-12-2009, 08:44 PM   #10
ok thx. I am having to adjust the brakes by hand anyway. I'll make sure I apply more to back but I want them to lock since I enjoy drifting.
Old 07-12-2009, 09:35 PM   #11
ok I just can't figure this out!!! :flam ing:: flaming:
So adjusting the brakes does not solve it! I take off the engine/flywheel and the noise stops (btw noise only when throttle applied which isn't in the vid so vid is usless), I test the flywheel and it doesn't make the noise either by itself (and anyway how could the throttle affect the flywheel when the car isn't running). WHAT IS UP WITH THIS?
HELP
Old 07-12-2009, 09:46 PM   #12
bump... again... sigh
Old 07-12-2009, 10:55 PM   #13
bump
Old 07-13-2009, 07:13 AM   #14
bump
Old 07-13-2009, 07:21 AM   #15
Im sure you can figure it out.
TT-01 Forum mailboxck Electric On-Road 2520 08-07-2017 02:28 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
TQ Racing SX8 vino1 Nitro Off-Road 3254 11-15-2012 02:53 PM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
kyosho rrr evo wc or xray nt1 08 DaNNy250RRR Nitro On-Road 30 11-23-2007 07:12 AM
