Old 07-12-2009, 12:22 PM   #1
Default quick question conserning diffs
Hey guys!
Yesterday I took my kyosho DBX out for a spin and I did some crazy donuts. I was thinking about taking off the front differential to try doing it at 2wd but do I need to take off the diffs between the front wheels? or is it just the one from the main gearbox to the front gearbox.
Nikzilla is offline   Reply With Quote
Old 07-12-2009, 12:36 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
You can remove the front CVD drive shaft that goes from the center diff to the front one..That will give you rear wheel drive only
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-12-2009, 12:46 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
like jaz said, you can take of the front shaft off (the one that goes to the diff) or you can take out the front two dog bones, i personally would do both because then the front wheels arent being dragged down by the diff
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 07-12-2009, 01:29 PM   #4
kewl thx
Old 07-12-2009, 02:18 PM   #5
Taking out the drive shafts alone will not work the diffs apply power to the side that has the least resistance. You will have to lock your center diff if you remove the front drive shaft.
Addiction RC
Scott51 is offline   Reply With Quote
Old 07-12-2009, 03:00 PM   #6
huh?
Old 07-12-2009, 04:05 PM   #7
NDHotbodies's Avatar
yes you will have to "lock" your out put on your center diff to get just rear wheel drive.. if you don't, all your power will go to the least resistence, the front, and all you'll do is not move.. had this happen when either a front or rear shaft breaks,and all you get is an engine revving up and not moveing...
self sponsored, flat broke, highly sought after test dummy for Hotbodies..
I don't spell wrong, I just use shorthand sum time..
NDHotbodies is offline   Reply With Quote
Old 07-12-2009, 04:06 PM   #8
If you remove the front diff or driveshaft you will not get any power to the rear wheels unless you lock the center diff.
Addiction RC
Old 07-12-2009, 04:15 PM   #9
how the heck do you lock the center diff?
dreaux is offline   Reply With Quote
Old 07-12-2009, 04:16 PM   #10
I have never done it but jb weld to fill the case should do the job.
Addiction RC
Old 07-12-2009, 04:21 PM   #11
Madbrad's Avatar
Trader Rating: 29 (100%+)
You can put some RTV in the center also to lock. But by locking it this way its not something that is easy to reverse if you want to go back to 4wd.
Madbrad is offline   Reply With Quote
Old 07-12-2009, 05:09 PM   #12
Jaz240's Avatar
use clay, play douh, or silly putty
Old 07-12-2009, 08:12 PM   #13
bjr48's Avatar
Since you didn't realize all of the work involved, I take it you probably won't be doing this anytime soon?
4 wheel drive donuts look cooler anyway sort of like a dog chasing it's tail
http://www.youtube.com/watch?v=MJFOmUPSFgs
Have fun either way, just don't burn up a diff overdoing it
bjr48 is offline   Reply With Quote
