Old 07-11-2009, 08:01 PM   #1
Trader Rating: 12 (93%+)
Send a message via AIM to killatoyota4569
Default Engine help please
Hey guys I have a freind who races Nitro so I sent him my engine and he says that the front main bearing is leaking. He says fuel comes out and air goes in.
Also he says the tool to remove the bearing is 150 bux and he doesnt have it. He says it is hard to remove these bearings and that the rear are easier. Is this true??? Y cant you just hammer it out or use a heat gun to losen her up?
The engine is an Old Novarossi TOP 3.5 .21 Buggy engine.
x-6 sq2/ x-60
Team KILL4T3Ch
killatoyota4569 is offline   Reply With Quote
Old 07-11-2009, 08:19 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Strip engine down to a bare case, put in the oven at 425F. After about 10 minutes, the bearing should fall out. You could use a heat gun too, but the oven heats the case evenly. Installation is easy if you put the new bearing in the freezer, heat the case again, and it should drop or slide right in. The rear bearing will fall out if you heat it enough, so make sure its in place if you doing the front bearing only.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-11-2009, 08:23 PM   #3
gkn0315's Avatar
Trader Rating: 126 (100%+)
yeah you can put the engine case in the oven and let it heat up then lightly tap the rear bearing out after you do this reheat the case and use thecrank to push out the front bearing hope this helps also make sure to reheat the case to put the new bearing back in you can also freeze the the bearing to help in this process gook luck
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 07-11-2009, 08:35 PM   #4
Not to knock your friend who's offering help, but I'd be concerned if he didn't know that you don't need a tool to remove the bearing. Strip down the motor and check the bearing to see if it's worn too. Most front bearings to a certain degree will leak out oil from the seal. That doesn't mean it has to be changed, it's just that you need to pay attention to the bearing and check it for wear more often.
When you heat the engine case, make sure you have some old baking mits ready and a small wood dowel. I've used that to tap out the bearing from the case out.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 07-13-2009, 05:06 AM   #5
Thank you guys for the great replys. I bought and engine off him that had Tooo much pinch the Pistion got stuck on me at the top stroke everytime, so he was breaking that in. I sent him my old Nova that was cutting out everytime at WOT. So that is the answer why he says its not working. So I guess I will talk to him agian and see what he says.
I would love to fix this bearing problem. I just dont know how to build these engines. are they hard?? Do they have schematics on these? Im a real car mechanic so I am sure it is not too much diff .
If there is any other info you can give me or hand down that would be great tooo. thnak you guys and have a wonderful day.
x-6 sq2/ x-60
Team KILL4T3Ch
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
FEMCA 1/8 buggy Qualifying RD 1 / truggy club race, 22nd March 09 leng Singapore R/C Racers 46 03-26-2009 01:20 AM
Engine Flame out issues. Please Help. rodneybarrett Onroad Nitro Engine Zone 24 07-04-2004 08:37 PM
Which .21 buggy engine to get for mbx5? please help rc_crazy22 Electric Off-Road 150 10-13-2003 06:45 PM
