Old 07-11-2009, 11:31 AM   #1
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Default Engine won't idle without glow started attached
Hey folks, I need a bit of help. I have an Ofna Force 32 that I picked up slightly used the other day. It has great compression, and starts right up. BUT...... I can't seem to find a spot where this thing will idle on it's own. It will idle and has good throttle response as long as the glow starter is attached, but AS SOON as I remove the starter it dies within a second. I've run the needles to the factory settings and started from there several times but still no luck. I know I've heard of this issue before but I just can't find anything on it. HELP!!!
Thanks,
Kris
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
Old 07-11-2009, 11:38 AM   #2
slaytanic's Avatar
Trader Rating: 20 (95%+)
Change the plug first thing. They can be bad even if they glow.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 07-11-2009, 12:02 PM   #3
Trader Rating: 27 (100%+)
I've found that an engine will idle bad if.. its too tight (not fully broken in yet), too loose which doesn't sound like your case, too rich or too lean (fuel coming out the exhaust?), or like said, a bad plug
Have you tried letting the engine fully warm up before taking the glow heater off? that any better?
My picco 28, I have to let it get hot before I pull the heater off.. but its pig rich and virgin tight
spawn_x is offline   Reply With Quote
Old 07-11-2009, 12:02 PM   #4
Try to warm the engine up with the glow igniter on and run it around a bit and when you take it off keep the RPMs up and see if it stalls.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 07-11-2009, 12:04 PM   #5
I guess everyone in Socal thinks the same
Old 07-11-2009, 12:04 PM   #6
losi_racer's Avatar
Trader Rating: 25 (100%+)
sounds like a bad plug, typical sign of it being bad.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
