Old 07-11-2009, 10:53 AM   #1
Default Engine cuts out. Novice needs help
Hi wonder if the experts can help me out here as i'm a complete novice about these things.
Once I start the engine while holding it up in the air, the wheels spin, which i know you trim the throttle down which i have done, however once i put it on the floor and the wheels are forced to stop spinning, the engine cuts out... Ive changed the settings on the throttle trim, but it always cuts out once i put it down
Any ideas how to resolve this?
thanks in advance
~Jonny
Jonny_b is offline   Reply With Quote
Old 07-11-2009, 11:52 AM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
thanks in advance
~Jonny
check the idle, check to make sure the clutch is free, to rich maybe,
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 07-11-2009, 12:34 PM   #3
Stupid question again.... how can i check if the clutch is free?
Old 07-11-2009, 12:45 PM   #4
Take the engine out, or you can just take the center diff/spur gear out and spin the clutch bell. It should not hang up on anything and it should spin smooth.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 07-11-2009, 02:20 PM   #5
Well it spins freely when the wheels are off the ground, but if the two front and back left hand side wheels are on the ground it locks..
Is that a good thing or bad?
Old 07-11-2009, 02:31 PM   #6
Trader Rating: 27 (100%+)
take the motor out and spin the clutch, that is how you check it. If it spins with wheels in the air but not on the ground, it might be stuck, thus your issue
spawn_x is offline   Reply With Quote
Old 07-11-2009, 04:11 PM   #7
losi_racer's Avatar
of course it will spin in the air, once you put the wheels on the ground your adding restiance
Old 07-11-2009, 05:42 PM   #8
oops, brain fart in how that came out..
I meant to say, on the ground if the clutch is not stuck the car should roll back and fourth freely, no?
Old 07-11-2009, 06:57 PM   #9
rossoh10's Avatar
Take the engine out..Take you clutch bell off and check to make sure you clutch springs are not broken or wore out...How long has it been since you changed your clutch shoes and springs
TEAM WTF
RC10B5m
rossoh10 is offline   Reply With Quote
Old 07-12-2009, 06:06 AM   #10
NitroWD's Avatar
should be yr engine clutch binding...listen to the guys' advise, remove engine and spin yr bell to check at least.
best would be to strip the clutch and rebuild.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
