Flywheel setup right?
Here is a pic. Does the flywheel look okay? Or is it too close to the edge of the chasis. I dont have a starter box at the moment so i cant put it on and check. Also is there too much space between the engine and flywheel?
LMK what you guys think
It should be more centered. Is there a shim behind the colette? You might want to remove that. It also looks like its too low. You will stall every time you land a jump if the flywheel hits the dirt, and if its hits a rock, theres worlds of trouble. You want to raise it up into the chassis some more. The starter wheel will go up into your chassis to engage the flywheel.
If there is no shim behind the collette, try a thinner collette or it just may not be tightened down enough. You surely want it more centered, and more into the chassis. with it being so far forward with chassis flex it may hit the chassis and stall
Put a shim behind the rear bearing in the clutchbell. That will allow you to move the flywheel back and the clutchbell forward. You will also shim the botom of the engine mounts. between the chassis and the mount, or between the engine tabs and the mount that will raise the flywheel you dont need much, maybe 2-3MM. try to get the flywheel about level or 1-2 MM higher than the top inside of the chassis. just make sure eveything is secure..you may have to do it a few times to get it right. The cahssis flexes allot and the engine is constant vibrations so you need to account for that, make sure everything is tight, and stable, or it will move when you drive it
I am glad I found this thread, I bought a used buggy and it would die in the oddest spots, well I just looked and the flywheel sticks a mm or two out of the chassis. Guess I should raise it, but how much, just enough so its in the chassis?
My rc8 is right and it has stalled before and I have a sneaking suspicion it was the dirt hitting it through the opening.
