clutch assembly problem..
hey ive got a losi 8ight buggy and i need to have it tip top shape for the race tomorrow and i dont want this happening again so im gonna ask what you guys think about it. ill go to the track and run a little but by the end of the day when im about to clean it i see that the smaller bearing(5x10) keeps busting out and shoots the clutch bell through my fuel tank. its happened to my twice in the past 2 times i went out to the track. i havent run it since but i changed out the whole clutch assembly. flywheel, bearings, shims, clutchbell. etc... please help me out because i DONT want this happening in the race and get a DNS or DNF
How are you setting your gear mesh between clutch bell and spur?
How much end play/slop do you leave on your clutch bell?
What shims are you using for your clutch?
The roller calls for 2 shims but I had the same problem with them in it. I took them out and havent had any problems since. With the shims in it is too tight when the nut is tightened which will cause the front bearing to fail very quick. Take it out and I bet your problem is solved.
your clutch bell is to tight. Check your shims - you want a little play between the clutchbell and flywheel.Read you losi manual and set it up how it say
Up to 1mm of "slop" in the clutchbell shimming is perfectly fine. You want a little bit of play so your bearings don't fail on you. As long as your mesh is not too tight and you have full contact on the spur with your pinion with through the 1mm of play you should be fine.
