Trying to start engine for the first time and 1 question:
#16
Well - sleeping on it seems to have made the difference. I wasn't even getting the engine to turn over last night. This morning it started up on the 3rd try.
I have it on a platform for now and I'm glad I did. When the engine started on its own, the wheels started to spin. The throttle looks to be as closed as possible. Can I assume I need to adjust my low needle a little to closer the throttle?
Thanks a lot for all the suggestions.
#17
I sure hope u heated it up if not you will be doing this all again for a new engine.....ALWAYS HEAT IT UP B4 STARTING.....The wheels turned because Im sure it loaded with fuel while starting it,and it set rich from the factory. As long as it stays running run it like that for a couple tanks then tune some.
#19
Jaz---somtimes it helps to turn the flywheel one full rotation to near TDC in the opposite direction. Like when viewing from the front of the car, turn the flywheel clockwise until it nears TDC. Then let the starter box spin up, push the chassis down against the starter wheel and the engine will have almost one full rotation to gain speed before it comes into the pinch zone.
