Old 07-10-2009, 03:07 PM   #1
Gumball's Avatar
Default HELP WITH FLAME OUT.
Ok, first let me give you all the info needed...
Kyosho ST-RR
Engine: .24 Pre-run Extech EBM
Pipe: Extech Bigboy
Glow PLug: OD (Hot)
Fuel: Byrons 30%
Engine runs good. about 3gallons through it. Idles great! Mileage awesome! Tune is good, lotsa smoke still. temp at Max:210 Min:190-195
Problem:
every time i have half tank left, and it does not matter if I was on the air, landing, hitting the breaks, WOT, or what ever, i flame out. The same exact point in the gas tank, when it reaches the seam part or where the tank is glued together. There are no visible leaks. After I pull it outta the track, i tried just starting it up without putting more fuel and it did fire up no problem.
So what could cause this? am i doing something wrong? did I not check everything i need to.
Please help....
Thank you.
I Drive.... (or try to drive LOL!)
KYOSHO INFERNO ST-RR w/ BCE K7-RR | EB-Mods EXTECH .24 | TRINITY BIG BOY PIPE | J Concept FUTABA | ACE SERVOs | AKA | BYRON's GEN 2 30% | RB S7 (back up) | Intellect LiPo | KHZ
and
KYOSHO INFERNO GT (GymKhana RC - Project)
Gumball is offline   Reply With Quote
Old 07-10-2009, 03:26 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Its really hard to diagnose Online, but the 4 main reasons for flameouts are:
Tune is off
Wrong/bad glow plug
Air leak
Clutch/bell/spring/mesh/bearing problem
Also check your pipe, and seals good
The reason it only shows up at 1/2 tank could be because thats when everything is nice and hot!!
I have also been hearing that the ramping putty comes lose from the Crankshaft and does not cause problems until it heats up and gets soft
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-10-2009, 04:43 PM   #3
rc-mike's Avatar
Have you checked the fuel line inside the tank?
rc-mike is offline   Reply With Quote
Old 07-10-2009, 06:25 PM   #4
PinoyCali's Avatar
Buy new engine lol . See you next week hope you
Fix the problem. Check the hoses and gaskets. Later bud.
PinoyCali is offline   Reply With Quote
Old 07-13-2009, 04:23 PM   #5
Gumball's Avatar
you're a big help!!!! you can't even start your engine! LOL! see yah bud!
and
Old 07-13-2009, 04:25 PM   #6
Gumball's Avatar
Tune is off
Wrong/bad glow plug
Air leak
Tune is not off i think. Idle is almost perfect. my main suspect is air leak somewhere in the tank. After it dies at half tank, I fire it up again, and it goes until tank is empty! very wierd!
and
Old 07-13-2009, 05:57 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
cCheck the tank. If it only happens when the tank is 1/2 way down there could be a prob with the tank. Also replace the fuel line as well. I have seen many trinity ex-tech engines with many many flame-outs. Its almost epidemic. Try the tank and I bet that solves your problem.
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
Hobbywing new burssless ESC testing autostyle Electric On-Road 73 03-02-2009 05:55 AM
how many time have you got burned by a soldering iron? mountaindr3wz Electric On-Road 53 02-05-2006 01:24 AM
Internet petition to have Homer Allman removed from R/C racing jesse james Electric Off-Road 299 07-28-2005 03:01 PM
Engine Flame out issues. Please Help. rodneybarrett Onroad Nitro Engine Zone 24 07-04-2004 08:37 PM
