Old 07-10-2009, 10:42 AM   #1
Trader Rating: 29 (100%+)
Default clutch assembly problem..
hey ive got a losi 8ight buggy and i need to have it tip top shape for the race tomorrow and i dont want this happening again so im gonna ask what you guys think about it. ill go to the track and run a little but by the end of the day when im about to clean it i see that the smaller bearing(5x10) keeps busting out and shoots the clutch bell through my fuel tank. its happened to my twice in the past 2 times i went out to the track. i havent run it since but i changed out the whole clutch assembly. flywheel, bearings, shims, clutchbell. etc... please help me out because i DONT want this happening in the race and get a DNS or DNF
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 07-10-2009, 10:56 AM   #2
How are you setting your gear mesh between clutch bell and spur?
How much end play/slop do you leave on your clutch bell?
What shims are you using for your clutch?
steener is offline   Reply With Quote
Old 07-10-2009, 12:28 PM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
I use a kyosho shim kit and usually use .3-.4 all behind the inner bearing and then use just a cap head screw at the end to tie it all together. The kyosho shim kit comes in .1, .2 and .3 sizes all in the same package.
Old 07-10-2009, 12:35 PM   #4
The roller calls for 2 shims but I had the same problem with them in it. I took them out and havent had any problems since. With the shims in it is too tight when the nut is tightened which will cause the front bearing to fail very quick. Take it out and I bet your problem is solved.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-10-2009, 12:37 PM   #5
your clutch bell is to tight. Check your shims - you want a little play between the clutchbell and flywheel.Read you losi manual and set it up how it say
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-10-2009, 05:38 PM   #6
not trying to get anyone mad but i have the right amount of shims and the clutch bell and center spur are meshed right. i cant find the problem. i dont have the stock shims in either, took those out right away. im using ofna shims.
Old 07-10-2009, 06:06 PM   #7
take the shims out and see what happens. I dont have any in mine but when I had the 2 that it called for the same thing happened. Trust me on this one. Run it without any shims..
Old 07-10-2009, 06:45 PM   #8
but then my clutch bell will be going everywhere....??
Old 07-10-2009, 10:04 PM   #9
Amoeba's Avatar
Send a message via AIM to Amoeba Send a message via MSN to Amoeba Send a message via Yahoo to Amoeba
Up to 1mm of "slop" in the clutchbell shimming is perfectly fine. You want a little bit of play so your bearings don't fail on you. As long as your mesh is not too tight and you have full contact on the spur with your pinion with through the 1mm of play you should be fine.
Erin Carroll
Do Not Taunt Happy-Fun Ball
Amoeba is offline   Reply With Quote
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
8ight clutch??? 1cougar1 Nitro Off-Road 28 01-21-2009 08:34 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
