Old 07-10-2009, 11:27 AM   #16
coviello's Avatar
bad idea to freeze bearings. when they unfreeze. guess what. condensation. then huh? whats that! condensation means water! which equals rust! hope you didnt try freezing it already
coviello is offline   Reply With Quote
Old 07-10-2009, 11:27 AM   #17
killabud's Avatar
In the past I have preheated the oven to like 350-400 and then put the block in and turn the oven off, wait 15 minutes and pull it out. if you have a heat gun you could use that as well but I think the oven might be your best bet in thsi case. I would almost put money on it that if you freeze the bearing it will slide right in. if anything it may need a little tap from a socket like someone else mentioned.
Tom Ulmer Team FISH-DO
---\\\Kyosho MP9 TKI3///---
\\\Futaba|OS Engines|VP Powermaster///
Baby Car!!!!!!!
killabud is offline   Reply With Quote
Old 07-10-2009, 11:29 AM   #18
killabud's Avatar
I have done the freez trick many times and hve no issues with rust. When putting the motor back togeather I use alot of oil on everything.
Baby Car!!!!!!!
Old 07-10-2009, 11:41 AM   #19
Trader Rating: 15 (100%+)
+1 always use a good after run oil when reassembly an engine. Or nitro fuel if you have nothing else. I usually coat the rear bearing and crank pin where the rod goes on really well. Anything to keep it from haven't that amount of friction of "dry starting" until the fuel gets to everything. I personally would not spend another 60 bux on that other tool just to put this back together. It will go just find a really big hammer! j/k
Another thing that I may have missed in the other posts where you stated and you would really suprised in panic mode how easy it would be to do, but i hope you took the carb off before you put it in the oven. lol
Jonathan Bell is offline   Reply With Quote
Old 07-10-2009, 12:01 PM   #20
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Ok, question for you: Could you use the crank with a washer and the flywheel nut to pull it back in?
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-10-2009, 12:02 PM   #21
DOMIT's Avatar
I've done it many times, and no problems yet.
Old 07-10-2009, 12:22 PM   #22
Garet Jax's Avatar
Trader Rating: 91 (100%+)
I've done many stupid things in my life, but putting plastic or rubber in a hot oven is not one of them
Garet Jax is offline   Reply With Quote
Old 07-10-2009, 12:26 PM   #23
Send a message via MSN to Adim_X
why cant you just put the bearing on the crank and push it back in. You seem to be making this process really difficult for yourself. Heat the block, freeze the bearing. Put bearing on crank, pull/push into hot block. Voila.
Adim_X is online now   Reply With Quote
Old 07-10-2009, 12:54 PM   #24
dude just go buy a new engine and dont mess with it
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
