Old 07-13-2009, 01:31 PM   #31
cary's Avatar
Trader Rating: 67 (100%+)
like Frank has said this Cold Fusion Fuel is the real deal and he has
not had a flame out since running Cold Fusion Fuel like he said I pit
for him and I will say it again that I have seen first hand the over
all performances of this fuel NO flame outs NO chasing the tune all day
I have maid the switch my self to Cold Fusion Fuel this is the only
fuel my new Pro Twister Mods O.S. speed will ever see and now that
I'm running Cold Fusion Fuel he will not have to run and get my car
1/2 way thru a main from a flame out
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 07-13-2009, 03:01 PM   #32
Gearhead racer's Avatar
Originally Posted by Frank L View Post
I posted this back on 7/10/09>>>
Cary is my pit guy>>>
Ad then to add to that I ran on Sat 7/13 with NO FLAMEOUTS, No tuning issues, No bad idle, No problems. My engine even came in hot at the end of the 20 min a-main at 280 and it did not flame. I could tell when I was driving that it was lean, the weather changed too much, but it still gave great power and excellent response. I took 2nd in that main. I am very, very, very pleased with coldfusion fuel. I run the magic 30% blend and thats all I want to put in my engines. Coldfusion has been very good to me. Thanks Ron & Vernon. Ohh yea did I mention NO FLAMEOUTS, come to think of it since I have been running coldfusion fuel exclusively I have not had a single flameout during a qual or race. I will ask Cary to confirm that because he is the one that has to run after my car if it flames, but there have been no flameouts that I can recall. Recently I changed a front bearing in my engine and I tore it all apart. I have about 2.5 -3 gal of coldfusion fuel in this engine (no other fuel has been run in this engine) and the piston and sleeve look untouched. There was the usual stuff on the top of the piston but the internal components were perfect. Next time I tear it apart I will take pictures. As for my opinion I think I have said enough. Try it you will love it, but you are warned you will be addicted. The warning of addiction should be on the bottle somewhere. haha
I would have to agree with that!
Originally Posted by rcgeezer View Post
You don't need a dyno or speed gun to determine which fuel you or your engine likes best. Straight out performance will be your deciding factor. Like Frank, I've run nothing but Cold Fusion fuel in my recently purchased Nova +4. All I can tell you is it maintains a nice low temp, it idles smoothly forever, makes GREAT power, and best of all...NO FLAME OUTS so you finish every race. But all that said Armaan, you'll only know if you like it by trying it...we're all sharing our opinions based upon what works best for each of us due to trial and error...in the end you'll have to do the same as no one but you can decide what's best for you. My satisfaction will come later when I can say "told you so!" Good luck!!
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 05-20-2010, 04:58 PM   #33
Throttle Nitro's Avatar
Default So. Cal Fuel
Throttle R/C Nitro is local here in Southern California and will deliver locally or can be will called out of brea, ca. Check us out at throttlercnitro.com
Throttle Nitro is offline   Reply With Quote
