Old 07-08-2009, 08:15 PM   #1
Default O.S. V-Spec needle settings
Can anyone tell me what the factory carb settings(including mid range needle) are on a v-spec?
Miniracer23 is offline   Reply With Quote
Old 07-08-2009, 08:26 PM   #2
the high is 3 turns out from fully closed, the low is extruding 0.5mm from the link body the mixture should not be touched its for very experience nitro engine tuners but it should be flush with the carb body. hope thi helps.
EastCoast is offline   Reply With Quote
Old 07-08-2009, 10:39 PM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Stock settings for the vspec are HSN 4 1/4 turns out and LSN 5 turns out. Thats how mine came.
Old 07-09-2009, 05:15 AM   #4
Unhappy
how i must turn this valve(foto) is LSN or HSN the name? i don't know.An the needle valve of the other side near to oil tubes? i run 25% nitro.I can't found the right balance.
sakis is offline   Reply With Quote
Old 07-09-2009, 05:32 AM   #5
NEEDLE SETTINGS: These are pre-set from the factory and require little or no adjustment (BS)
High Speed - 3 turns out from fully closed
Throttle Stop Screw - 1/2 turn out from fully closed
Mixture Control Valve (low speed) - Flush with indentation on screw head pointing at 2:00
http://manuals.hobbico.com/osm/21vzb-vspec-manual.pdf
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-09-2009, 06:49 AM   #6
Trader Rating: 32 (100%+)
just make sure you have same carb.
there's 21C, 21J, and 21JS. they're all little different.
I believe this is for 21C and 21J, I use this setting for both my speed, and one has 21C and other has 21J
HSN 3 turns out from full closed
MID 1 turn IN from flush with caburetor body
LSN Flush with Ball link body
HSN needle is by the fuel intake,
LSN is on the sliding carb
MID is on the opposite side of the LSN
only setting I touch is HSN.
Z01B | Xerun 150A 2000kv | Hitec | Desire-power 6S LiPo
Z01T | Tekin RX8 1700kv | Hitec | Desire-power 6S LiPo
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 07-09-2009, 06:54 AM   #7
according to th emanual, mixture control valve is the MID, and meetering needle is the low speed.
Old 07-09-2009, 07:24 AM   #8
ok
Old 07-09-2009, 12:39 PM   #9
I tried tuned the afternoon.when I close the throttle after 2 seconds is the correct idling rpm (idle open 0.8) why? should i close the meetering needle a little?
Old 07-09-2009, 01:53 PM   #10
Sorry dude - - - - WHAT?
Old 07-09-2009, 02:18 PM   #11
Frank L's Avatar
Drive it for a few mins on the track, tune, drive a few mins on the track, tune ect. You will know when you get it right. Be patient and dont stick to the exact # of turns and other peoples settings, they will get you close but every engine/ carb is different.
Old 09-28-2009, 05:53 PM   #12
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
Sorry to bring up an old thread, but the V-Spec 21J carb settings are confusing me. I tried for about 2 hours today just to get a running tune without success. I have tried multiple sources to try to get the default settings for the needles.
In this thread, devilchrist states the correct position for the needles is
According to token, the answer is:
Then, in this other thread post here, jpalessi says:
IDLE: 1 full turn (from just fully closed)
LSN: 4 full turns from closed
MRN: 3-3/4 turns from closed (flush) 10 o'clock
HSN: 3 full turns from closed
Meanwhile, the manual that came with my V-spec says:
HSN - 3 turns in from closed
LSN - 0.5mm beyond (out from) ball link end
MSN - flush
Then, the online manual here, says:
LSN - flush w/ ball link end
MSN - 1 turn in from flush
So the question is: which is actually correct? The only thing every source agrees on is the HSN needs to be 3 turns out from closed.
I am seriously about to send this carb back to O.S. or something and pay to have it properly setup again. This is just getting frustrating.
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 03-13-2010, 05:58 PM   #13
bump
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
