Old 07-08-2009, 04:15 PM   #1
JPierson's Avatar
Questions?? CLUTCH SHOES--LEADING or FALLOW??!!??
What is the best way to run your clutch shoes
for different response?? Carbon or aluminum??
Lead or fallow?! Thanks for the help!!
HB D8 & D8t GRP .21 & O'DONNELL SS.21
JR 8711 & 9100s & Hitec 7955TG
M11 2.4 FHSS-2 •TEAM*TERRIBLES•
"I know I can't drive!! You still ACT like you can!!"
JPierson is offline   Reply With Quote
Old 07-08-2009, 04:18 PM   #2
AutieBender's Avatar
Removed
Team Losi/Novarossi/Losi Tires/Nitrotane/JR propo/Upgrade Graphics
Quicks R/C Hobby Shop
Surprise, Arizona
AutieBender is offline   Reply With Quote
Old 07-08-2009, 04:37 PM   #3
megasaxon's Avatar
Trader Rating: 25 (88%+)
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
Originally Posted by AutieBender View Post
Removed
trailing or following as you said is the norm, and worki the best that way
Team Associated RC10GT
Team Associated RC10GT2
megasaxon is offline   Reply With Quote
Old 07-08-2009, 05:08 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I didnt think you could put them in the other way. The engine spins counter clockwise and the shoes need to trail behind the pin.
Old 07-08-2009, 05:11 PM   #5
If you run aluminum then I would mount my shoes trailing. Because of the grab that al. shoes have.
With the carbons you could go either way depending on how much punch you want. Leading for more grab and go, trailing to make a little easier to drive. It depends on the traction available.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 07-08-2009, 05:28 PM   #6
Jon Moore's Avatar
If you install them Leading, they'll have a lot of snap to them. Probably would be great for super high bite, or drag racing.
Jon Moore is offline   Reply With Quote
Old 07-08-2009, 06:03 PM   #7
well it's harder to install the shoes leading, and some clutch tools couldn't do it.
cheapskate.brok is offline   Reply With Quote
Old 07-08-2009, 07:01 PM   #8
Trader Rating: 19 (100%+)
You can run them either way but I have only heard of the "backwards" way and with only carbon composite or nylon shoes. A guy at my local track says sometimes in the indoor-winter he will run them that way because of the high bite track.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 07-08-2009, 07:02 PM   #9
Im confused on this one. The shoes go one way. If they were backwards they wouldnt spread apart to engage the clutchbell. Never heard of this.
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 07-08-2009, 07:15 PM   #10
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
go to chapter 2 under clutch and you can see
http://www.teamxray.com/teamxray/sho...p?file_id=4461
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-08-2009, 07:15 PM   #11
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Actually the shoes will go on wither way, you just hadnt considered it cause thats the way you were taught, just like me. But no reason why they wont go either way. Like they stated, with "leading edge" they bite real hard and fast. Better for drag race or super high traction tracks, otherwise you'll be spinning wheels badly. Possibly some of the "European style" flat tracks with carpet or concrete approaches to the jumps.
sickpuppy1 is offline   Reply With Quote
Old 07-08-2009, 07:18 PM   #12
Jaz240's Avatar
Trader Rating: 52 (100%+)
yes they will. The centrifugal force of the flywheel will open your shoes to engage the bell in either direction
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 07-08-2009, 07:29 PM   #13
You will need a radicle retune of the bottom if you change to leading.Leading with alum shoes = zero slip,loss of bottom end & heavy load on your eng. I would use stiffer springs than you are now if you go leading or try composite shoes but people that do it by accident end up driving much more consitant till they get pissed that the motor wont tune right/like normal.
butch man is offline   Reply With Quote
Old 07-08-2009, 10:51 PM   #14
JPierson's Avatar
so more snap is basicly the only gain?
Old 07-08-2009, 10:54 PM   #15
Yup.
