question about losi hitec aluminum servo arm. HELP
i just got the losi aluminum steering servo arm for hitec and i have the 7955TG servo and it is VERY tight. i literally have to pry it off for 10 minutes and i know that shouldnt be right...can someone help me that has the aluminum arm and a 7955TG servo!! thanks
-Garrett
-Garrett
I have to wiggle & almost get a screw driver on my & pry all but I think on that car its a 5955,
Now that I think of it ti might ba a jr servo its on but either way the losi arm is just really tight & thats normal & better than loose.
but should it be THAT tight? literally i sit there at least 10 minutes and i try putting a screwdriver slanted under it to pry it but i dont want to screw up my servo. that plastic on the servo isnt very tough to be able to use that as suport to pry it off.
-Garrett
-Garrett
Yes!!!! I have the same set up for steering. They fit realllllly tight. After a few times of pulling it off and on it will loosen up but very slightly. To get mine on I literally put as much weight as possible and it finally fits. Same process for getting off the servo.
The first time I had to use pliers to get it off.
WOW and my JR horn on my JR serovs give me no issues - smooth on and smooth off, hahahahahahahahahahahahahaha
Really hum, never had one strip been using the same one from the origianl 1.0
Easiest way to remove a tight horn is with a set of side cutter's......Slowly clamp the horn but be careful if you press to hard you will nick the splines when the horn pop's.....this is the Only way i can get my losi horns off my hitec's.....ramming a flat heat in and prying is imo a bad idea....the top case has a bearing right there and any distortion of the top case might cause issues.
Ive never seen a losi horn fail...but dynamite ive seen twist tweak break and bend...imo the losi is alot stronger.
I like the Dyn horn but have bent & broken a few. Oddly enough the ones I bent on purpose for clearance have not bent any more or broken,I think it depends on your stand off. If you want a long horn thats as strong as the losi Hanger 9 makes a good one.
Oh & to get mine off I grab the end of the horn & wiggle & pull with fingers at the splines.The side cutter trick wont work on lay down servos wich is about 1/2 of mine.
