Old 07-07-2009, 07:33 PM   #1
Default distorted glow plug
what does that look like. I put almost 2 galons on my latest plug and at the track it starting backfiring and dieing out at medium to full throtle. I took my glow plug out, and it's really grey not quite white and it's thicker then normal. My question is, is this a distorted glow plug? I read that a distorted or broken wire is a major danger zone, to lean, possible engine damage. But my engine never went over 230. So what is a distorted plug? If anything i would say it's coroded. and yes it's looks pretty coroded and fat. Could this just be the oddonnel fuel that has stained everything it touches?
hope i didn't hurt my engine.
dreaux is offline   Reply With Quote
Old 07-07-2009, 08:01 PM   #2
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
Grab a new plug just like it and compare the elements inside the plug. If the used one's element has moved compared to a new one, then that's a distorted plug. Your engine was probably lean if it was backfiring and it might need a head shim to lower the compression a little.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 07-07-2009, 08:24 PM   #3
no same place but really really grey. Yeah new plug richer settings. thanx good night.
Old 07-07-2009, 09:38 PM   #4
You're running a V-spec right?
No shimming needed if this is the case. Richen her up an hour and get back to running. 2 gallons is a lot on a plug though. I change my plugs at one gallon to make sure that the plug doesn't cost me a race, and I don't loose any performance.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
STS engines sparksy Onroad Nitro Engine Zone 2774 02-03-2013 06:05 AM
Glow plug chart - is there one? Mark_Australia Nitro Off-Road 10 11-23-2008 05:18 PM
Temp ok, plug wire distorted. NitroWD Onroad Nitro Engine Zone 8 04-03-2008 09:22 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
