Old 07-07-2009, 12:09 PM   #1
Default Sand in tires
I don't seem to wear out my tires, they only get packed with sand so they get really heavy and out of balance. Thus I stop using them. Boiling/de-bonding and re-gluing tires is really not my thing, I hate it!
Preglued tires usually have holes in the rims, do you guys cover these or do you just live with heavy tires till they get worn out?
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 07-07-2009, 12:13 PM   #2
you need plug those hole in the rim and then use sum rubber snipper and carefully cut out two hole in the actual tire
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-07-2009, 12:17 PM   #3
Right, ok.
That's what i did with my monstertruck tires in the old days to get rid of water.
Will this work/make my heavy tires better/lighter or is this a prep for my future tires?
MBX-6
Old 07-07-2009, 12:18 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Cover the holes in the rims with a small piece of electrical tape. Punch 2 holes in the tire 180 degrees apart with an adjustable leather punch. This obviously only works with unmounted tires. Most good premounts(IMO AKA's are the only good ones) come with holes in the tires already. Best bet is to buy unmounted tires and glue them yourself.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-07-2009, 12:20 PM   #5
there we go, did not know what they are called
Old 07-07-2009, 12:23 PM   #6
My tire gluing is not compatible to racing of any sort.... It's just sad. I really can't afford any more pratice
MBX-6
Old 07-07-2009, 12:34 PM   #7
Dude it takes patience and practice.....................
Old 07-07-2009, 04:52 PM   #8
sickboy's Avatar
Trader Rating: 72 (100%+)
Must be nice not to wear out tires, I go through at least 3-4 sets a month.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 07-07-2009, 05:09 PM   #9
dishsoap's Avatar
Hmmm I am jelous. That means you get to race much more than I do. I am using AKA tires though. So far I can easily get 3 to 4 races out of my I-Beams.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 07-07-2009, 07:50 PM   #10
air8's Avatar
Here is the pair I've been using the last couple of years. I only use the largest bit for RC tires and the other bits for after Holiday Meals with the family. LOL.
I must have found them on sale locally cause I only paid $12 USD.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 07-07-2009, 07:57 PM   #11
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
You can cut holes in already-mounted tires using a pair of small side cutters or lexan scissors. Just gather up the center a little with your fingers and make two cuts. Works great, and the sand will come out of your tire the first time you drive on them afterwards.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 07-07-2009, 11:18 PM   #12
Leather punch pliers will do the same thing. Pinch the center of the tread folding ot & punch half a circle,when you let go of the tire it will make a full circle. Every time I forgot to punch before I would burn a hole in the tire with a dremmel bit.Took years of that till it dawned on me the punch pliers would still work
BTY I just saw the same pliers I have in the $5 bin by the checkout stand at tru-value last week,I got mine out of the $10 bin a few years ago.
butch man is offline   Reply With Quote
Gamers..What are you playing right now?? speedemall Chat Lounge 1082 10-23-2011 08:38 PM
1/8 off-Road Buggy Thread Teeka Singapore R/C Racers 4016 09-23-2009 06:59 PM
Any current TCs fully dialed out of the box? iblumberg Electric On-Road 30 11-17-2005 01:25 PM
