Old 07-08-2009, 06:35 AM   #16
Integra's Avatar
Originally Posted by butch man View Post
I like the Dyn horn but have bent & broken a few. Oddly enough the ones I bent on purpose for clearance have not bent any more or broken,I think it depends on your stand off. If you want a long horn thats as strong as the losi Hanger 9 makes a good one.
Oh & to get mine off I grab the end of the horn & wiggle & pull with fingers at the splines.The side cutter trick wont work on lay down servos wich is about 1/2 of mine.
the Losi horn is short....the Hanger 9 is Super Long and will not work on a losi without being cut down....the side cutter trick should work on lay down servo's....you just have to pinch in between the horn and the top case...i dont see much difference between a stand up and lay down servo in that respect.
