Old 07-06-2009, 07:25 PM   #1
halfman's Avatar
Default need help with my mbx6`s steering
i built the kit and i have a spektrum dx3.0 controler and when i turn the steering wheel all the way the mbx6s tires will still steer alot further. my steering epa is at 125 on both sides. i dont know what to do so please help
halfman is offline   Reply With Quote
Old 07-06-2009, 07:41 PM   #2
turn the epa down on the radio.
team2zon is offline   Reply With Quote
Old 07-06-2009, 07:46 PM   #3
Send a message via MSN to Adim_X
I am not sure exactly of your problem but here are two solutions.
If the servo is pushing past the point of turning the wheel to full lock, then you need to back the end points down.
If the servo is turning all the way via the radio, but you are not getting full steering throw on the car and you epa is already maxed out. I would make sure the dual rate is turned up all the way, and then reset your end points.
I have a feeling one of these two solutions will fix your issue.
Adim_X is offline   Reply With Quote
Old 07-06-2009, 07:54 PM   #4
sickboy's Avatar
Trader Rating: 72 (100%+)
The Mugen has A TON of steering. Start with your EPA at 100 and adjust from there. Trust me, that will most likely more than enough. I dont think the Mugen hits lock until its at like 90deg.....
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 07-06-2009, 08:02 PM   #5
halfman's Avatar
no what i was saying is i need more steering not less. it will turn alot more but i dont know how to get it to.
Old 07-06-2009, 08:07 PM   #6
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
make sure your steering link is the correct length....via the manual. both the servo saver and the servo horn should be pointed at 3 o'clock with wheels straight.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 07-06-2009, 09:01 PM   #7
sport10's Avatar
A longer servo arm will give more throw if needed.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 07-06-2009, 11:59 PM   #8
markt311's Avatar
Trader Rating: 32 (100%+)
I have always noticed this with the DX3.0 and 2.0, the radio doesn't seem to drive the servo far enough. Try a longer servo horn as a bandaid, or try using someone else's transmitter with your servos and I have a feeling the problem will disappear.
Bottom line I would invest in a quality transmitter, the DX3S will work with your rx and I have had zero problems out of mine in 6 months of weekly racing.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 07-07-2009, 04:22 AM   #9
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
If you go to Jake's (JCG) Saturday (and bring the manual for your radio please) I'll see if I can help you. It could be dual-rate, epa, various things... We can also try binding your receiver to my M8 (I have a Spektrum module in it) to make sure you don't have a servo issue. (Doubtful, but it is a test that we could do.)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
RC8 Factory Team vs MBX 6 need some feedback robbdny Nitro Off-Road 79 12-14-2008 10:37 AM
