Old 07-06-2009, 06:57 PM   #1
DiaRh34's Avatar
Send a message via AIM to DiaRh34
Default diff oil
Is there a guide somewhere that tells what weight oil will do what.Someone explained it to me like some weights will help with on power/ off power steering and all that.Just looking for a chart/guide for reference.
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 07-06-2009, 08:12 PM   #2
Google Hudy buggy and truggy setup guide.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 07-06-2009, 08:36 PM   #3
Gearhead racer's Avatar
"Seeing the world on 2 wheels"
Losi Ten-T SCTE~Tekin SC4X 4.5~ Tekin RX8
Gearhead racer is offline   Reply With Quote
Old 07-06-2009, 08:42 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
I have it on PDF PM me an email and I can send it to you.
Old 07-06-2009, 08:45 PM   #5
strngdze's Avatar
Trader Rating: 16 (100%+)
Here is a good article by Chad Bradley.
http://www.rc411.com/pages/howto.php?howto=24
__________________________
OFNA Racing - Nitrohouse.com
strngdze is offline   Reply With Quote
Old 07-06-2009, 08:52 PM   #6
Frank L's Avatar
Straight from the HUDY set up guide.
DIFF OIL
THICKNESS CHARACTERISTICS
Front
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent,
especially it can lose forward traction (and steering)
during acceleration out of corners
Thicker • Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too
much power and sometime “cook” the oil in the center
differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Rear
Thinner • Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
Old 07-06-2009, 09:48 PM   #7
DiaRh34's Avatar
Thanks everyone
Taco
Old 07-07-2009, 03:22 AM   #8
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
DIFF OIL
Front
Thinner
Center
Thinner
Thicker
the throttle
Rear
Thicker
• Reduces wheelspin
this kind of info that makes us all love rctech. All shared. Nice work Frank L. It helps me too.. esp on the thicker center diff points. Thanks
if u around my area.. i already treat u at least a jug of beer
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-07-2009, 06:30 AM   #9
fatdaddy's Avatar
download the hudy setup book from them here: http://www.google.com/url?sa=t&sourc...g6X0pb_XPPKy0Q
fatdaddy is offline   Reply With Quote
Old 07-08-2009, 07:39 AM   #10
Wink
what oil i need?
sakis is offline   Reply With Quote
Old 07-08-2009, 07:54 AM   #11
Originally Posted by sakis View Post
what oil i need?
whatever floats your boat , it depends on what you want how you drive - its hard to say
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-08-2009, 08:00 AM   #12
Frank L's Avatar
what oil i need?
How's it drive what does it do that you don't want it to and what does it not do that you want it to. Start with the base line and adjust as per the hudy set up guide.
Old 07-08-2009, 08:04 AM   #13
How does this Hudy thing work - all buggies - truggies are different the feell the push the pull, steering all different.
Old 07-08-2009, 08:33 AM   #14
Frank L's Avatar
You start with what ever setup you are running or most mfg's have a reccomended starting point and then you make adjustments to get the truck or buggy to do what you want it to. The guide just shows you what to do and which way to go. For example ad above on the diff oil, if the front is unloading badly then make the center diff oil thicker. The setup guide let's you know how to make adjustments to get the performance that you are after. It does not say all center diffs need 10k. It's used as a tuning tool. Hope that helps.
Tamiya TB-Evolution III rc-zombies Electric On-Road 7237 11-16-2016 05:09 AM
Serpent to 1/10th EP Touring Kit S400 rcforum Electric On-Road 3296 05-31-2013 01:48 PM
All HAWAII State Racers Post Here shortyboy Racing Forum 5236 06-04-2009 06:39 PM
Reducing Tire Wear Riketsu Nitro On-Road 28 02-08-2008 09:36 PM
KING OF TOURING RACE HD-F1 Georgia Racing 114 10-20-2007 08:22 AM
