Old 07-06-2009, 02:20 PM   #1
buggydad's Avatar
Angry Hitec servo issues need HELP
I'm running hitec servos in my truggy.Steering hitec HS-7955TG works great.Throttle hitec HS-985mg and when ever its powered it makes a loud humm Almost like you have to much EPA but louder after about 15 sec the servo starts to get HOT.I played with different RX ports and still does it.I can get it to stop by applying brake very slowly then once i move it again it begins to humm again????????????????????????????????Any suggestions
buggydad is offline   Reply With Quote
Old 07-06-2009, 02:44 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
those 985mg servos dont last very long
throttle/brake servo takes more of a beating than the steering servo
some will disagree but ............................
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-06-2009, 02:45 PM   #3
If I'm not mistakin, thats a analog servo. If you have a radio with HRS mode, make sure it is OFF. It will fry analog servos. Digitals only in HRS. Trust me, I'm speaking from personal experience.
Miniracer23 is offline   Reply With Quote
Old 07-06-2009, 02:50 PM   #4
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Sounds like you have a linkage issue. If not, send it back to Hitec. They'll send ya a new one.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-06-2009, 02:52 PM   #5
houston's Avatar
this is a definite possibility
Old 07-06-2009, 07:58 PM   #6
buggydad's Avatar
Yup that was the issue turned of HRS and fixed it thanks.Now will this have any ill effects on the 7955
Old 07-06-2009, 08:59 PM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
You will need to run both digital servos if you want to use that mode. Analog servos are better for throttle/ break as they are not as finicky with the linkage, but both digital allow the radio to run its full potential. I have run all digital for the last season and this season without problems.
Old 07-06-2009, 09:05 PM   #8
ehames005's Avatar
Trader Rating: 74 (100%+)
I don't mean to hijack the tread but what is the HRS mode? and does the M11 have that?
Thank you to my 2017 supporters:
Sworkz--Amainhobbies.com---ProTek Rc---Huston's Engine Service
ehames005 is offline   Reply With Quote
Old 07-06-2009, 11:15 PM   #9
houston's Avatar
futaba and it stands for high response system
i would be surprised if your servo made it through the hrs mode . how long did you run it like that ?
Old 07-06-2009, 11:33 PM   #10
Most good servos are able to handle HRS mode for a while,at least long enough to figure out something is wrong.Dont take what was sad earlier too seriously the 985 is not really a bad servo its just that we all have been spoiled by the new seryos that came out in the last few years.The 985 will never be a 7955 but its also 1/2 the price & would be considered one of the best servos 5yrs ago. Over kill is just the norm now is all. When you say hot if you mean wow thats unusual the servo should be fine,but if you mean it burned my finger when I touched it send it in before it dies in the middle of an expensive race day.
butch man is offline   Reply With Quote
Old 07-07-2009, 12:42 AM   #11
dishsoap's Avatar
Correct me if I am wrong but digital servos have a slight chatering/ticking noise especially when they are cold.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 07-07-2009, 12:43 AM   #12
Trader Rating: 29 (100%+)
yes they do!
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 07-07-2009, 12:53 AM   #13
But they should not get hot just sitting idle.
Old 07-07-2009, 04:01 AM   #14
buggydad's Avatar
I only hade the 9855 plugged in for about 30 sec i was just installing it in my truggy.I reilized something was wrong right away.It didnt get so hot that it burned my fingure but it was hot enough to be surprisedLike i said i switched off HRS and now its fine I was just going to run it but if you guys think theres a chance it may be done maybe i wont
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
