Old 07-06-2009, 01:30 PM   #1
Garet Jax's Avatar
Trader Rating: 91 (100%+)
Default Locking the flywheel so I can remove the clutch nut on Losi 2.0
Hello all,
I am slowly working through my disassembly of the Losi 2.0 8ight RTR buggy. I am learning a lot as I go and having fun doing it.
I am now trying to remove the clutch nut so I can remove the flywheel. I bought a flywheel wrench a few days ago expecting to see 4 flywheel posts that I could use with the wrench to restrict the flywheel movement so I could unlock the nut.
Of course the Losi flywheel doesn't have posts so the wrench is useless. I could use a pair of pliers or a lock wrench on the serrated edge of the flywheel, but will undoubtedly damage it if I do.
Are there other things I can use or do to restrict the flywheel movement so I can remove the clutch nut?
Thanks a lot.
Garet Jax is offline   Reply With Quote
Old 07-06-2009, 01:36 PM   #2
fatdaddy's Avatar
just use a regular size tounge and groove pliers. (channel locks)
if you hold it tight and dont let it slip it wont mess up the flywheel. besides the flywheel is going to get messed up on its own. dont worry about a couple little scratches you might put in it
fatdaddy is offline   Reply With Quote
Old 07-06-2009, 01:38 PM   #3
losi_racer's Avatar
Trader Rating: 25 (100%+)
the best thing to do is get a Slip-Joint Adjustable Pliers. clamp down on the flywheel, just dont let it slip, it wont damage it at all
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 07-06-2009, 01:39 PM   #4
Moderator
Trader Rating: 76 (100%+)
they make s piston stop tha threads into the glow plug hole and stops the movent of the piston.
roadrashracing is offline   Reply With Quote
Old 07-06-2009, 01:43 PM   #5
Garet Jax's Avatar
Is this the GRP engine tooling kit or something else?
Old 07-06-2009, 01:44 PM   #6
Stanton's Avatar
Originally Posted by Garet Jax View Post
Hello all,
Thanks a lot.
If the flywheel is the same as the pro kit...Use a small Crescent wrench to hold where the square part of the flywheel is and use a 9mm glow plug wrench to remove the nut. Hold the end of the crankshaft against a hard surface. Take the handle of the glowplug wrench and smack the back of the flywheel and it will pop right off. (if you hit it right).
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 07-06-2009, 01:50 PM   #7
Joey Powell's Avatar
NEVER EVER use a piston locking tool for any reason! They put ALOT of stress on the con rod. Use Channel locks to hold the flywheel while you loosen the nut and a cheap gear puller from Auto Zone, Advance Auto, etc. to pull the flywheel off the collet
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Old 07-06-2009, 01:50 PM   #8
Garet Jax's Avatar
It sounds like it is the same flywheel as what is on the pro kit. Although it is not perfectly square there may be enough material to get some bite with a crescent wrench.
Okay sounds like I might have a few options.
In terms of the smacking of it using the glowplug wrench, I tend not to have those things work for me very easily. Instead I bought a battery terminal puller to help me remove the flywheel.
Old 07-06-2009, 01:58 PM   #9
From my engine Modder -
The best tool to use is the dynimte piston lock, its like 10 bucks - take off the back plate and insert the locking tool.you have no chance of stripping the fly wheel or breaking the piston......
And this does not put stress on the conrod, this comes from pro factory team drivers.
http://www.amainhobbies.com/product_...ing-Tool-12-21
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 07-06-2009, 02:21 PM   #10
LabRat99's Avatar
I wrap a shop rag around the flywheel, hold it with channel locks, and use a deep socket & ratchet for the clutch nut. I bought a "brake parts puller" from Auto Zone that makes a perfect flywheel puller. It was about 20 bucks and makes pulling the flywheel a breeze.
LabRat99 is offline   Reply With Quote
Old 07-06-2009, 02:25 PM   #11
buggydad's Avatar
I hade to use this tool a few times but only when needed like when the flywheel itself is loose.Otherwise to remove the nut just use channel locks like mentioned prior
buggydad is offline   Reply With Quote
Old 07-06-2009, 02:40 PM   #12
houston's Avatar
crescent wrench , you can even leave the shoes on
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-06-2009, 02:54 PM   #13
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 to the crescent wrench. And if the crankshaft slips and the engine turns over, insert a large zip tie folded in half into the exhaust of the engine. Basically making your own piston locker, but without the damage they do.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 07-06-2009, 03:14 PM   #14
I would recomend use a heat gun or hair dryer to heat up the fly wheel so that it will come off the collet much easier. some times they stick and no matter how hard you smack the fly wheel it wont budge.
good luck, and what motor are you replacing the stock RTR with.
rc_racer1 is offline   Reply With Quote
Old 07-06-2009, 03:33 PM   #15
Frank L's Avatar
Trader Rating: 148 (100%+)
I use channel locks with the wheel wrapped in foam rubber or I use these channel locks from Tamiya with the non-scratch surface on them. They work great but they are pricey.
CLICK HERE
