Old 07-05-2009, 11:20 PM   #1
Default eb modded head distorting plugs
Hi my ninja jx is slightly distorting glow plugs, it is running slightly on the rich side with no play in the rod, however it did not start distorting plugs until i put in an eb modded head. I installed the head with the supplied shim and it runs great but just keeps distorting plugs has anyone else had this problem? and does anyone have a solution as i would like to keep running the modded head.
Cheers
daveblount is offline   Reply With Quote
Old 07-06-2009, 07:46 AM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
Add one more .1mm shim.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-06-2009, 08:40 AM   #3
yep, or lower nitro.
maxflo777 is offline   Reply With Quote
Old 07-06-2009, 08:41 AM   #4
Racecrafter's Avatar
Trader Rating: 25 (96%+)
+1 .1 shim
And for the record, what fuel are you running?
Racecrafter is offline   Reply With Quote
Old 07-06-2009, 09:15 AM   #5
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
DO NOT ADD ANY SHIMS! RUN ONLY THE ONE 0.004 SHIM.
the button is NOT the reason your blowing plugs.. Try a different fuel, and or get a better tune on your engine.
what plugs are you using???
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 07-06-2009, 09:35 AM   #6
Toiffel's Avatar
Trader Rating: 52 (100%+)
i would listen to Jose, he knows a ting or two......
Toiffel is offline   Reply With Quote
Old 07-06-2009, 10:07 AM   #7
imaxx21's Avatar
Send a message via AIM to imaxx21
when you say 'distorting' what do you mean?
did you re-tune when you changed the button?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-06-2009, 10:23 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
Sounds like a tuning issue to me. I use this head button on a speed and only use the shim enclosed with the eb head button. Works perfectly. If you are distorting the wire in the plug sounds like its too lean.
Old 07-06-2009, 11:54 AM   #9
i run it on byrons gen 2 25% with p3 plugs. It seems to be tuned fairly spot on but slightly on the rich side (plenty of smoke and light brown coloration on plug body and wire) When i say plug distortion i mean very slight distortion of the wire and will still run fine but obviously do not want to run with a distorted plug. It never did this with the standard head and used the original plug for the first gallon and a half then put the new head button in and i go through a plug every race day.
cheers
Old 07-06-2009, 12:21 PM   #10
jpalessi's Avatar
cheers
run a p4 plug and that problem will be solved.
Joe Alessi
www.Lucky7RC.com
Old 07-06-2009, 01:57 PM   #11
ok cheers for the help i will try the p4 plugs and get back to you hopefully with good results
Old 07-06-2009, 09:24 PM   #12
Frank L's Avatar
I had a GRP do exactly that to the P3 plugs. It would run flawlessly on race day and then the next day have trouble starting. I would replace the plug and then it would fire right up. Tuning was good, slightly rich if anything, temps good and pleanty of smoke. I switched to a P4 like Joe says to do and then the problem was solved. I dont have that problem with the speed with an EB mods head button the P3 plug works fine. Then again the P3 plug was designed for the speed engine. Bottom like like Joe said switch to a P4.
Old 07-06-2009, 09:33 PM   #13
Mr. Twister's Avatar
a modded head button will automaticlly lean the motor, go to a cooler plug like JP said and you will be good, the motor is burning the fuel much more affectivly with the new button while creating more power, we are running the 97T and they haul the mail. Good luck
Brian Carey
615-838-5373
Tennessee Oval Performance
Check us out on Facebook
Mr. Twister is offline   Reply With Quote
